Go Back   Badcaps Forums > Troubleshooting Hardware & Devices and Electronics Theory > Troubleshooting Game Consoles & Other Weird Devices
Old 03-26-2018, 04:57 PM   #1
birdboy385
City & State: cheswick
My Country: United States
Default Netgear NightHawk X8 Ac5300 / R8500
Hello everyone, I have the forementioned router that I happened to stumble across at my local goodwill. It seems to at least partially turn on but I can't seem to connect to it to do any kind of resetting. I looked in the back and found the actual reset button but it's been broken out. I could probably rip the router apart to jump the joints where the button would be but I'm not sure if the router is even working properly to begin with.
You can see below the power and internet lights are a amberish color. The internet will blink occasionally and will fully go out if i unplug the cable. The usb and 2.4 and 5ghz lights are a dim white. If i plug anything into the rear ethernet ports the light will glow brightly. I also am not able to see any broadcasted wifi network. I'm not sure if there's something wrong with the router or if it could be set to a different mode like a bridge mode or if the DHCP server is completely disabled. Either way I'm unable to get a gateway hooking up a computer to it.
File Type: jpg 29680454_10212291461066734_1554470563_o.jpg (394.5 KB, 22 views)
birdboy385 is offline   Reply With Quote
Old 03-26-2018, 06:44 PM   #2
CapLeaker
Leaking Member
CapLeaker's Avatar
City & State: Atlantic Canada
My Country: Canada
Line Voltage: Ground, 0Hz
I'm a: Hobbyist Tech
Default Re: Netgear NightHawk X8 Ac5300 / R8500
I'd replace that reset button first with something simple like 2 wires or solder in some switch from the junk bin. Then try to reset the router and see what happens next.
Old 03-27-2018, 02:01 AM   #3
Th3_uN1Qu3
Believe in
City & State: Bucharest
My Country: Romania
Line Voltage: 230VAC 50Hz
Dim lights sounds to me like low power, which could very well be caused by bad capacitors. Pull it apart and show us some guts.
Originally Posted by PeteS in CA View Post
A working TV? How boring!
Th3_uN1Qu3 is offline   Reply With Quote
Old 03-27-2018, 04:41 AM   #4
wcalifas831
City & State: california
My Country: u.s.
Definitely try to add a reset button. It could have been set as an access point and you want it to reset back to defaults to mess with it. Also like previously mentioned open it up let's see the inside. Change the caps to see if that is causing the low power. Also make sure you're using the right power adapter that gives it the right voltage.
wcalifas831 is offline   Reply With Quote
Old 03-27-2018, 11:06 AM   #5
birdboy385
I don't see any obvious burn marks on the board. I got the best pic i could with the cruddy phoen i have. It looks like there are 3 points for the button. I'm not sure what points i would need to gorund. I can probably take a paper clip to at least attempt a factory reset.
Old 03-27-2018, 01:53 PM   #6
stj
stj's Avatar
City & State: Europe
those buttons are east to get, used in loads of junk and probably on ebay at 5 or 10 for a $
Old 03-27-2018, 02:54 PM   #7
birdboy385
I'm sure they are, but for the moment I do not believe i have any available...other than ripping one of the other buttons off the same board. That's why for the moment I just want to try shorting out the proper contacts to attempt resetting it.
Old 04-04-2018, 11:38 AM   #8
Spork Schivago
Your Awesomeness
City & State: Corning, New York
My Country: United States of America
Line Voltage: 120VAC 60Hz
Yes! We had a similar problem with a router that was given to us. No wifi. Tore it apart, swollen cap. Replaced that, works fine!
Also, to the OP, I might be mistaken, but I think that particular router is in the list of Netgear routers affected by the Krack exploit / hack / whatever you want to call it, and you should definitely check to see if it is. Then update the firmware to protect yourself. Once you get it working, of course.
Spork Schivago is offline   Reply With Quote
Old 04-04-2018, 11:41 AM   #9
Spork Schivago
Your Awesomeness
Do you have a multimeter? If so, set it to continuity mode and test the other working buttons to figure out what pins are what.
The other two look identical, if they are, they should have the same setup. That way, you can see what pins are connected when you push the button, with one of the working ones. I'd do this with the router off, not on.
Old 04-04-2018, 03:42 PM   #10
stj
stj's Avatar
dont remove the bad one, it has 4 pins and may be in series with other parts.
Old 05-13-2018, 10:40 AM   #11
tibimakai
City & State: Los Angeles/San Dimas, CA
It may also be bricked. You will need that button fixed first, for sure.
Found this on another forum:
This is my final procedure after I fixed the second router r8500.
1) J4 connector pins : 1 2 3 4 pins are visable by looking the motherboard and they are located in the front view.
and j4 mark is located next to #1 pin. 1 gets green color, 2 gets white color, 3 gets green color, 4 is not connected.
2) open the bottom cover by removing the 6 tork screws.
Take the cover half way out so you can see the j4 plug and plug the serial cable.Turn on the router.
3) Start Putty let it run for a minite or so and start sending control c commands until you will see CFE.
4) on CFE type nvram erase you will see a 0 as an answer.
5) On CFE type tftpd you will get tftpd server ready ::
6) go on comand mode dos cmd>tfttp -i 192.168.1.1 put C:\r85.chk
r85.chk will be your old firmware located on the c:\ main directory
7) Now you will see a blue led on the #1 port flickering comminicating.
8) if what you did is correct then you will get from dos and putty file tranfered successful.
9) Now hold the reset button with a pin and turn the power off.
10) with the pin on reset turn power on and waight for 3 reboots let the pin go.
11) waight for 2 minutes you will see many led's comunicating and final the main led will be normal.
12) The router is now ready to be configuerd.
13) The network name and password is located on the white paper top right or at the bottom of the router.
I did 2 units the first one it took 1 week the second one it .5 hour.
Good luck.
peter11742
A small correction.
Pin #1 green Pin #2 white pin #3 blk which is the gound Pin #4 is not connected red.
peter11742
tibimakai is online now   Reply With Quote
Old 06-04-2018, 02:27 PM   #12
birdboy385
Hey everyone, sorry I've been majorly AFK for the past few weeks. I am reading all of these responses and will be reviewing all of it to proceed further. I will update once i have more information.
Old 06-07-2018, 01:21 PM   #13
DJ_MIX
DJ_MIX's Avatar
have you tried setting you network adapter to static ip and then open web browser and type in the default ip and see if you get to main menu?
DJ_MIX is offline   Reply With Quote
Old 07-15-2018, 01:49 PM   #14
birdboy385
Hello everyone. Sorry I did play a bit more with the router. I found the aforementioned buttons have 4 legs. The 2 outer legs are the legs for the button jack and the inner 2 appear to be for the button itself. I was able to get about 2.7 volts measuring the inner legs. I tried shorting those 2 inner legs but didn't seem to make a difference. I even tried making a solder bridge but no apparent effect. I did notice that if I disconnect the router from my adjacent router I do get the Internet light to illuminate. If i hook up a device to one of the output ports from the router to say a laptop. that lights up as well and I seem to get an infinite connecting loop from the device I'm using. Not sure what that leaves me with at this point. For the moment, I am unable to try the suggestion to use a serial connection using the jumpers and a terminal as i do not have the proper cable. I'm not sure how i'd wire something like that anyway unless there's a special cable built for that.
Old 07-20-2018, 04:00 PM   #15
birdboy385
anyone have any thoughts? given these symptoms.
Old 07-20-2018, 07:06 PM   #16
CapLeaker
Leaking Member
CapLeaker's Avatar
My Country: Canada
maybe MAC or IP filtering is on, or the router doesn't give you any IP. Maybe hook up a TTL to it and see what the terminal spits out? Maybe clear the NVRAM while your in it, then reboot it and see what that gives.
Old 07-22-2018, 09:21 AM   #17
birdboy385
I'm not sure how to access functions to do that. I know above there was mention of hooking up a serial connection to the board on the j4 connector but I have no idea how i'd do that
Old 07-26-2018, 07:53 AM   #18
birdboy385
So at this point based on what I know. I ended up just completely removing the reset button and did various combinations of soldering the various 4 legs of the button to force a connection. Nothing seemed to have any effect there. I can get an Ip4 address but that could be my computer caching a previous IP address from a different connection. I did try resetting my ethernet adapter as well as clearing my DNS cache. No effect. I also do not get a default gateway. The only thing I can think of to try would be to get that serial connection working but i'm still not sure how to go about doing that.
Badcaps.net Technical Forums 2003 - 2018
Copyright ©2000 - 2018, Jelsoft Enterprises Ltd.
