Badcaps.net Forum
Go Back   Badcaps Forums > Troubleshooting Hardware & Devices and Electronics Theory > Troubleshooting Power Supplies and Power Supply Design
Thread Tools Display Modes
Old 11-05-2019, 04:23 PM   #1
starengose
City & State: Dreux
My Country: France
Line Voltage: 230VAC 50Hz
I'm a: Hardcore Geek
Default Problem with TX650 Corsair Power Supply
Dear All,
Sorry for my english.
I need some help concerning this power supply. It doesn't works anymore, any output voltage.
I put some pictures of power supply I trying to test it most of capacitors tested are ok. It's difficult to test small cms capacitors sometimes my multimeter doesn't display something. I've tested also with power on but impossible to get logical values for example I have alternative voltage in parts of continue voltage.
I've tested most of component I changed a opto-coupler but I don't think it was damaged. As you can see in picture 225300 when I open cover I found burn part (metalic ring) between two tracks. I removed it but you can see burn marks.
If someone can help or can get a shematic because it's difficult to me to fix board with alternative voltage because I don't have oscilloscope.
I have also a problem with cms diode I don't know the sense.
Thanks for your help.
starengose is offline   Reply With Quote
Old 11-05-2019, 05:39 PM   #2
RJARRRPCGP
City & State: North Springfield, Vermont
My Country: USA
Line Voltage: 118-127V 59-63.5 Hz-> actualizar: pérdido de voltaje
I'm a: Knowledge Seeker
Default Re: Problem with TX650 Corsair Power Supply
Code:
RJARRRPCGP system error: One or more photos unreadable. (blurring)
Well, one of the photos appear to be improperly focused.
__________________
Asus P6T6 WS Revolution
Core i7 Extreme "Bloomfield" 965
Asus Strix GeForce GTX 970
Windows 7 SP1
SoundBlaster ZXR
Corsair TX850M PSU
Looks like I have a laptop that kills a desktop PC!
Received on November 4, 2019:
MSI GF63 Thin 9SC-649US
"Don't eat yellow snow!" -Salem
RJARRRPCGP is offline   Reply With Quote
Old 11-06-2019, 12:50 PM   #3
starengose
City & State: Dreux
My Country: France
Dear Rjarrrpcgp, sorry I am not expert to take picture properly.
Here you are thanks.
Old 11-06-2019, 05:16 PM   #4
xmetal
Those green electrolytic capacitors in the last photo look like they are bulging and will likely need replacing. Do you have an ESR tester for checking the caps?
xmetal is offline   Reply With Quote
Old 11-07-2019, 12:08 AM   #5
RJARRRPCGP
My Country: USA
Doesn't look like actual bulging. (no bulge at the vent seams)
Old 11-07-2019, 01:07 AM   #6
starengose
City & State: Dreux
My Country: France
Thanks for your replies, I confirm that most of caps are ok I've disoldering most of them (big one not cms) and values are ok. Now I am suspected UP3861P and components around it (small board outside main board in picture). but I need way to test it only with multimeter.
Old 11-07-2019, 08:29 AM   #7
sam_sam_sam
City & State: Sunny Jacksonville FL
My Country: USA
Line Voltage: 120 Volts 60 HZ
This just me but when I find any type switching power regulator I suspect that might be problem I replace it if the part is easy to get
__________________
9 PC LCD Monitor
6 LCD Flat Screen TV
1 Dell Mother Board
15 Computer Power Supply
All of these had CAPs POOF
sam_sam_sam is offline   Reply With Quote
Old 11-08-2019, 12:52 AM   #8
starengose
City & State: Dreux
My Country: France
Dear All, I fixed PSU, I've only refresh solders on small board (caps) but about diode I put in same sense than other in board (cathode to ground) but with multimeter in one sense I've got 0.5V and other sense I've got 2.8V thereas normally I have to get only 0.5V in one sense and other infinite. I'll test it with motherboard and graphic card to know his durability.
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Badcaps.net Technical Forums © 2003 - 2020
Powered by vBulletin ®
Copyright ©2000 - 2020, Jelsoft Enterprises Ltd.
