I have a K52F REV 2.2 motherboard that don't turn on the HDD or detect it. The HDD don't spin or do any turn on noise.
All other functions are working, including the DVD drive, just the HDD part is faulty.
The tests i have done:
1) Replace HDD - Same happen
2) Test Laptop HDD on other computer - Works
3) Check motherboard sata trace continuity to hdd - All ok
4) Check voltage lines on HDD connector at SATA - OK (3.3v and 5v present)
5) Update BIOS - Same happen
6) Plug or unplug HDD while PC is on - PC auto turn OFF
I don't have an oscilloscope to check the sata data line.
I don't know much about how the HDD should work, but does the hdd require the data line to turn on? aka spin? When i disconnect a data line from a desktop but keep the power the HDD spins.
What can be wrong here?
I have attach the datasheet.
