Old 03-07-2018, 09:44 PM   #1
triplefour
City & State: Hilo, HI
Default Vizio P502UI-B1E has no backlight, no voltage from driver board to LED's
All voltages on the PSU seem fine. i have 12v and 24v going to the Driver board and Mainboard. strangely this PSU does not have a wire where the 5V should be. also theres some other unused pins that are labeled for 3D stuff.
never worked on a tv where the PSU didnt have 5v...
the tv responds to the power button, increasing the PFC from 170 or so to 400 and staying there, plus all output voltages seem fine and stable. another press of the power button followed by a long press will result in the tv shutting off (as these models with only one button do)
on the driver board CN806, is the cable coming from the PSU, and it reads 24v for pins 1-4 and 0v for pins 5-8
also on the driver board, CN805 is the cable coming from the Mainboard and reads as follows:
1-0
2-0
3-3.03
4-0
5-0
6-0
7-0
8-4.87
9-0.03
10-12
11-NC
of course i have no idea what the voltages should be on this connector...
because none are marked, on the top or the bottom, or on the mb.
and also there are no voltage markings for the cables that go to the LED's
but at the end of the day, i have 0v on all pins of all 4 connectors that go to the LED's
because PSU seems to be outputting correct voltage, and MB is responding to pwr button to turn on and off, i lean towards the problem being with this driver board.
only thing has me worried is i think i should be able to see image with a bright flashlight but i cannot.
i would like to test for sound but its hard to change the inputs blind...
i find a lot of LED driver boards on ebay for pretty cheap, but i'd like to be a little more sure before just throwing parts at it.
thanks for any input!
Don't fear the repair...
triplefour is offline   Reply With Quote
Old 03-07-2018, 10:00 PM   #2
budm
budm's Avatar
City & State: S.F. Bay area
Line Voltage: 120V 60Hz
Default Re: Vizio P502UI-B1E has no backlight, no voltage from driver board to LED's
So you have 24V feedin the LED driver board when you turn on the TV, correct?
The LED driver board has 4 converter circuits (4 inductors L801 ~ L804 for circuits) but not 100% sure yet because the caps are only rated at 35V so they may not be boost converter but may be buck converter. One way to tell is to get the P/N of IC 601 ~604 to see what they are.
Based on this picture: https://www.badcaps.net/forum/attach...1&d=1520484273
What DC V do you get on the right side pin of those 4 inductors when TV is turned on? they should have at least 24VDC when the boost converters are not turned on by the BL-ON signal.
Old 03-07-2018, 10:22 PM   #3
triplefour
thanks for the reply. i checked those 4 inductors L801 ~ L804 and found 0v on either side of them.
i have 24v at the connector
Old 03-07-2018, 10:33 PM   #4
triplefour
i think you meant IC 801 ~ 804
heres a pic
markings are as i can tell:
Z1269012
ZA4S16
Old 03-08-2018, 12:56 AM   #5
triplefour
..and i cant seem to find a datasheet for it
Old 03-08-2018, 09:17 AM   #6
budm
budm's Avatar
heres a pic
Z1269012
ZA4S16
You are correct, they are 801 ~ 804.
Old 03-08-2018, 09:24 AM   #7
budm
budm's Avatar
The IC is made by Alpha & Omega semiconductor: http://www.aosmd.com/
AOZ1269QI-02 Buck converter.
See spec sheet so you start checking Voltages.
Old 03-08-2018, 11:55 AM   #8
triplefour
could you tell me how you found this datasheet? i was unable...
Old 03-08-2018, 01:35 PM   #9
budm
budm's Avatar
I use 'Z1269QI2' as shown in your picture.
You wrote it down as 01.
Old 03-08-2018, 03:28 PM   #10
triplefour
wow, good eye. i never would have seen that as a Q ....i do see that it wasnt a 1 though, i need to take more time and look more carefully next time. thank you
Old 03-08-2018, 03:33 PM   #11
budm
budm's Avatar
You can see how '1' is printed on the first line and on the second line compared to 'I' in the first line.
Old 03-09-2018, 12:07 AM   #12
triplefour
yes i totally get that but seeing that as a Q instead of a 0 or a O .... that takes skill
Old 03-09-2018, 01:59 AM   #13
triplefour
ok so i checked those IC's and the pins are really close together so i couldnt get some of the ones that were in the middle, but TON pin reads 9.6v and all the ones i could safely get a read on are 0v.
heres a picture. anything with no voltage written is 0, and the pins on the ic are unknown/0
i get the same readings for all 4 sections
Old 03-09-2018, 08:31 PM   #14
triplefour
any thoughts?
Old 03-11-2018, 12:17 PM   #15
Kg74
City & State: Edina, mn
My Country: Usa
Follow the trace and take your measurements from that point.
Kg74 is offline   Reply With Quote
Old 03-12-2018, 08:37 PM   #16
al1415
City & State: leesville,la
My Country: usa
Is their a service manual for this TV? P502ui-B1E
al1415 is offline   Reply With Quote
Old 03-12-2018, 09:55 PM   #17
triplefour
i havent been able to find it. i would really like to know what the expected voltages are on the connector going to/coming from the mainboard to the LED driver, so i could tell if the problem is in the driver board or further up...in the mainboard
there needs to be a project where everyone who has a tv, even though it isnt broken, could take a look at what the voltage should be and give us this precious info
i did find this on youtube: https://www.youtube.com/watch?v=PJxlACogZQA
its for a very similar tv (just missing the E at the end)
and its from shopjimmy. they say its a common problem with this tv if you have no backlight, to change the eeprom at u202....but they dont even mention doing the flashlight test to make sure you have picture, or what it would mean if you did or not have picture...
i hate just buying stuff on a guess though, even an educated one. i'd like there to be some definitive test that shows the eeprom is bad before i bother replacing it
edit: i found a place claiming to have the service manual but they want 13$ for it
http://www.service-manual.net/ashop/...=catalogue.php
Old 03-12-2018, 10:23 PM   #18
budm
budm's Avatar
So pin 2 (EN) is staying low on all 4 IC's?
If it is then you need to trace to see where pin 2 goes to next, so far it looks like pin 2 of each IC is connected to 220 resistor, so I expect the other end of each one of those resistor will be tied together and then goes to one of the connector pin.
Old 03-12-2018, 11:55 PM   #19
triplefour
yes, i cant exactly probe the pin itself, but the very next thing the trace from EN goes to: R8207 reads 0 on both sides
and so does the thing it appears to be connected to (i have a hard time following these things... do i have to flip the board over? shine with a light? use a magnifying glass... probably)
but anyway it seems like it goes to
C8066
which is also 0 on both ends.
as for seeing all 4 of these sections tied together and going to one connector pin, i have not looked closely enough (i guess), and also which connector? the one from the psu where i have 24v or the one from the mb where i have a few v+ as well?
what did you mean about the 220 resistor? i cant see that anywhere
Old 03-13-2018, 09:30 AM   #20
budm
budm's Avatar
From the pictures I can see the resistor that is connected to pin 2 has '220' printed on top.
Tracing the connection on the board is part of the troubleshooting that needs to be done and it can be time consuming. But at this point if there is no EN HIGH signal to turn on the circuit thane there will be no Voltage for the LED strings.
Badcaps.net Technical Forums 2003 - 2018
Copyright ©2000 - 2018, Jelsoft Enterprises Ltd.
