Badcaps.net Forum
Go Back   Badcaps Forums > General Topics > General Capacitor Questions & Issues
Thread Tools Display Modes
Old 03-15-2018, 01:35 PM   #21
Per Hansson
Per Hansson's Avatar
City & State: ----
My Country: Sweden
Line Voltage: 230v 50Hz
I'm a: Knowledge Seeker
Default Re: Antec PSU - Panasonic FS capacitors
rugger: Good, look here for an example of what happens when you don't:
https://www.badcaps.net/forum/showthread.php?p=435863
__________________
Per Hansson is offline   Reply With Quote
Old 03-22-2018, 08:43 AM   #22
Behemot
Behemot's Avatar
City & State: Prague, 504'52.22"N, 1423'30.45"E
My Country: CZ
Line Voltage: 230 V/50 Hz
ZLQ is only current D10 4700/6.3 series, AFAIK. Though most 3300/6.3 will be also OK, like Chemi-Con KYB.
__________________
Behemot is offline   Reply With Quote
Old 03-22-2018, 10:15 PM   #23
rugger
Already have the 3900/6.3's Panasonic FS. Will probably install them tonight when I get a chance.
Will see if this whole project is a bust or not
rugger is offline   Reply With Quote
Old 03-23-2018, 06:39 AM   #24
rugger
Seems like I have been successful. Power supply is now working again!
Changed all electrolyic capacitors except a 10uF Teapo hiding under a coil that was pretty much impossible to get out. Didn't feel like taking the coil out for a capacitor just to change a capacitor that is still good!
Old 03-23-2018, 09:45 AM   #25
stj
stj's Avatar
City & State: Europe
My Country: some shithole run by Israeli agents
I'm a: Professional Tech
the usual method when re-capping a psu is to pull the heatsinks out with the semiconductors still mounted on them.
i do anyway - it helps brush out the dust.
stj is offline   Reply With Quote
Old 03-23-2018, 03:54 PM   #26
rugger
Wow (I thought removing the semi-conductors and heatsinks was mainly only done by reviewers to better identify the different regulators)
That is far more work than just working around the heatsinks with a pair of pliers.
I've done some basic measurements:
5V rail, measures about 5.1V with about 20mV ripple.
12V rail, measures dead 12V on the dot and I get about 40mV ripple.
I'm pretty happy with that.
Old 03-24-2018, 12:09 AM   #27
rugger
Ok, so I'll just recap all the capacitors I replaced:
4 x 4700uF 10V - Replaced with Panasonic FS 3900uF 6.3V
2 x 3300uF 16V - Replaced with Panasonic FS 3000uF 16V (was a pain to fit as caps were bigger than original)
2 x 1uF 50V - Replaced with Panasonic PW 1uF 50V
1 x 220uF 16V - Replaced with Rubycon YXJ 220uF 16V
2 x 1000uF 10V - Replaced with Rubycon ZLH 1000uF 10V
1 x 470uF 25V - Replaced with Rubycon YXG 470uF 25V
2 x 10uF 50V - Replaced with Rubycon YXF 10uF 50V
1 x 47uF 35V - Replaced with Nichicon PS 47uF 35V
1 x 22uF 50V - Replaced with Rubycon YXF 22uF 50V
Thanks for everyone who gave advice, pretty cool to see this PSU working well again.
Old 03-24-2018, 12:09 AM   #28
Behemot
Behemot's Avatar
My Country: CZ
Exactly, I never do that unless absolutely necessary, takes too much time…
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Badcaps.net Technical Forums 2003 - 2018
Powered by vBulletin ®
Copyright ©2000 - 2018, Jelsoft Enterprises Ltd.
