Thread Tools | Display Modes |
#41 |
City & State: Italy
My Country: italy
I'm a: Knowledge Seeker
![]() 3.3 and 5 volt in new laptop generally get on after pressing power botton. could be 5 volts are present for usb charge. before go on, check if on power botton u have 3.3 volt on some pin, chech if on battery connector u have some 3.3 volts present, check if after pressing power botton, u have 3.3 volts on l100, or if some light power on or u have some beep, or if fan spin.
if 3.3 on power botton and battery connector, but no 3.3 on l100 after pressing power botton, pu100 could be bad and need new one. also post all pu100 volts again. |
#42 |
City & State: Around the country...
My Country: Hellas ( Greece )
![]() In pin4 of power button flex i get 1.6v, no other volatages.
I get 5v at one pin of USB In PU100 i get: pin1 2.3v pin2 19.6 pin3 19.6 pin4 19.6 pin5 19.6 pin6 0 pin7 0 pin8 0 pin9 0 pin10 0 pin11 4.5v pin12 2.9v pin13 0 pin14 0 pin15 0 pin16 3.3v pin17 3.3v pin18 0 pin19 0 pin20 0 What do you think? Last edited by Andreasbest; 07-03-2018 at 10:39 AM.. |
#43 |
City & State: Italy
My Country: italy
![]() kbc pin 127 voltage ?
edit: measure also rtc battery volts too Last edited by dellxps15; 07-03-2018 at 02:33 PM.. |
#44 |
![]() Pin127: 1.599v
RTC battery is not on board, it's detachable with cable and i have disconnect it. |
#45 |
City & State: Italy
My Country: italy
![]() put rtc battery and measure again
#46 |
![]() With battery 2.813v
#47 |
City & State: Italy
My Country: italy
![]() ok with rtc battery, if u press power botton , it goes to 0 ? and light, fan spinning or beep from speakers ? 3.3 volts comes from l100 ?
#48 |
![]() You mean PL100? If yes, then no 3,3v when i press power button.
Also no fan or led or other activity, pin127 goes to 0v though. Last edited by Andreasbest; 07-04-2018 at 10:26 AM.. |
#49 |
City & State: Italy
My Country: italy
![]() try replace pu100
#50 |
![]() Ok.
It write AWV8RN but on the schematics writes SY8286BRAC_QFN20 Gonna try to found it on a older board. |
#51 |
City & State: siliguri
My Country: india
Line Voltage: 220vac,60hz
I'm a: Professional Tech
#52 |
![]() Customer decide to order a new motherboard (400euro cost) not my problem anymore BUT the old motherboard left here so i might fix it for my self.
From where do you suggest me to get the AWV8RN from? China market or are all non working cheap copies? |
#53 |
City & State: Italy
My Country: italy
![]() get from ebay.... if u dont need them fast they are very cheap from china.
look for SY8286BRAC 7€ from uk or 3.39 from china see-ic. Last edited by dellxps15; 07-10-2018 at 02:46 PM.. |
#54 |
![]() Yes i just wonder if they are reliabe from Chine or just cheap low quality fakes that don't work.
Although no other seller except Chinese from eBay so i'll probably get them from there. |
#55 |
City & State: sadasd
My Country: asdsa
![]() I have same problem in my laptop
i have no 3.3 volt so i remove the jumper and test 3.3 volt back but there is a short circuit after the 102 jumper so when i remove all jumper for 3volt and apply 3volt on jumper 102 to the +3VALW side the cpu and cpu resister get hot what is the proplem |
#56 |
![]() Dellxps mate i managed to get and replace AWV8RN
Now i need to check the motherboard without the rest of the laptop (customer got it with new motherboard) I think the adaptor for this Dell has the usual Dell id chip so probably the 19v and ground only in connector will not work, i need to sacrifice a Dell charger to power it on, right? Last edited by Andreasbest; 10-04-2018 at 12:34 PM.. |
#57 |
City & State: Italy
My Country: italy
![]() 19 volt lab psu on + side of connector is fine. just make sure to solder the wire on the right polarity.
#58 |
![]() I think this is the correct polarity, please confirm.
Also in JPWR1 the shortcircuit for power on is the pin 1 (3vALW) + pin 3 (POWER_SW)? |
#59 |
City & State: Italy
My Country: italy
![]() yes that's correct. pjp1 is vin and pjp2 is gnd. look schematics page 50
on shcematic there are 8 pin, but tnx to pjp point we can track back the correct soldering point. edit: with lab power supply set to 19 volt, check if any current drain when in idle, then try powerint it on anche check Amperage consumption. do also other measure like 3.3 volt comes in and so on. Last edited by dellxps15; 10-05-2018 at 04:14 AM.. |
#60 |
City & State: balıkesir
My Country: turkey
![]() I have this problem +3.3 V Power buton ok but Not Spi bios PSU CURRENT 00,1 or 00,4 pu100 making very little warming maybe change PU100 fix this problem (NOT LIGHT CHARGER)
Thread Tools | |
Display Modes | |
