Hi friends, I need help on this ACER Aspire 5733 LA-6582P PEW71.The problem with this is dead laptop when i check in bench lab it shows from 100miliams to 200 then goes down fluctuating.When i check on the dc in 19v ok and on the first switching mosfet PQ59 both sides have 19v but on the second mosfet PQ52 source side ok have 19v but on the other side which is drain voltage flactuate from 15v drom to 11v then goes to 15 and dropping,the same also on the resistor PR351 with a mark R020 both sides voltage flactuating from 15v to 11v. Anyone can help me please need advise on this please
ACER ASPIRE 5733 Voltage flactuating
Re: ACER ASPIRE 5733 Voltage flactuating
Originally posted by String2016 View PostI removed pr351 still the same problem fluctuating i checked pc248 and 249 caps no short
Originally posted by String2016 View Poststill the same issue i replace isl U17 and tried again still the same issue voltage flatuate on PQ52 drain side.anyone can help me on this please
Isl chip has 1pin gnd rest of the pin is not gnd do this get multi-meter put on continutiy mode and put black on gnd and swipe the red accross all pin of isl pins ignoring the gnd pin se if any pins beep if they do beep investigate from their were beep coming from track it.
Make sure no power is on.
Check isl datasheet for pin layout output.Last edited by Stevie2001; 05-26-2018, 03:07 PM.
