i have a Benq FP91E.
Some months ago it had 2 seconds to black so i opened it and saw some elkos looking dead so i changed it and the screen was working again.
Some time after that it again had 2 seconds to black so I changed all elkos (except the one on the left top corner, because I think they are only for sound?) and resoldered the transformers and C5707 (on top of the picture).
It works some months but now the screen is black (not even 2 seconds) and also the power led isn´t working.
I measured the C5707 and think they are ok...
pin 2->3: 560Ohm
pin 3->2: ~120kOhm
pin 1->2,1->3: ~18MOhm
Mainfuse and Picofuse are also working (0.3 Ohm)
The board is still "cheeping" like it was before when i opened it with power plugged in.
As you can see the a trace "burned" as i tried to run it disassembled, hopefully nothing bad happened, the trace has still a connection.
Greetings from Austria.
pin 2->3: 560Ohm
pin 3->2: ~120kOhm
