Hi Badcaps.net!!!\
So I have a few questions to ask and need your assistance!
So recently my Westinghouse 19" LCD went out (Model: 19w4) without any warning. Rather than throw it away, I decided to crack it open and see if I can revive it once again. After snooping around the internet for possible clauses and answer, the most apparent and easy to troubleshoot solution was to check the capacitors.
So I cracked open the casing (Albeit, broke a few tabs > ) and viola! the powerboard (DAC-12M030) contained two bulged capacitors. So, I went ahead an ordered a repair kit that was offered by LCDalternatives on ebay and replaced all caps (7 of them). I was expecting everything to be fine, but alas, it was not.
The LCD monitor did not even light up! Upon further analysis on the monitor with a flashlight shined into the panel, I do not even see images other than lines.
With the power plugged in and the monitor on, all I can hear is sporadic ticking noise (kinda sounds like a laser beam from a sci-fi show) every time the monitor cycles. The power LED light just blinks and every blink yields the ticking noise.
I honestly do not know what else could be wrong. All "proposed" caps were replaced and I still cannot get a picture or even light.
Help!!
Picture below:
All replaced caps can be identified by the "curved T" shaped top compared to the "crosshair" shaped top.
I will try to get pictures of the back soon.
Help!!
Picture below:
