Badcaps.net Forum
Go Back   Badcaps Forums > Motherboards with Bad Capacitors > Other Devices with Bad Capacitors
Thread Tools Display Modes
Old 08-16-2017, 09:45 AM   #1
lcdcaps1
Default Netgear Gs116v1 Bootup bad caps
Hi
I have a Netegear Gs116v1 that had swollen caps, symtoms
I replaced the swollen caps but i think that that pads were corroded before i could do anything
I plugged the power without anything connected in the switch and works but on boot up only the first 14 lights flash and not all of them.
Also sometimes the lights do not flash when i plug in the power but all the ports work ok
I was wondering if someone could confirm this is normal and share a schematic diagram for this switch PCB or tell me where i solder a wire from the two caps to another point
The two caps are PCE6 AND PCE8
The ratings for these are 470uF, 16V
It turns on without these caps
Please can some help
Many Thanks
lcdcaps1 is offline   Reply With Quote
Old 08-16-2017, 05:04 PM   #2
diif
City & State: Midlands
My Country: England
I'm a: Professional Tech
Default Re: Netgear Gs116v1 Bootup bad caps
Photos would help.
diif is offline   Reply With Quote
Old 08-17-2017, 05:08 AM   #3
lcdcaps1
Does anyone have the schematic for this or the same switch please
I do not have a powerful camera to take decent photos
Many Thanks in advance
Old 08-17-2017, 08:37 AM   #4
diif
My Country: England
There are no Netgear schematics available for any of their products.
Even a cell phone photo is better than no photo.
Old 08-18-2017, 01:13 PM   #5
lcdcaps1
Hi
All
does anyone have the same switch as this please that can help me please
Many Thanks
Old 09-01-2017, 11:56 AM   #6
momaka
momaka's Avatar
City & State: VA (NoVA)
My Country: U.S.A.
Line Voltage: 120 VAC, 60 Hz
I'm a: Hobbyist Tech
Ok, STOP right there.
Running any electronic equipment with parts removed that you aren't sure what they do is a recipe for disaster.
If you want to save the above router, I strongly suggest NOT to use it again until those caps are replaced. Some electronic circuits will go absolutely ballistic without proper filtering - in particular any DC-DC buck regulators. I've had quite a few electronics die due to bad caps (because the bad caps went so bad, that it was almost as if the caps were not in the circuit)
You don't need a "Pro" camera for this. Even a cell phone picture will do if you have nothing else. Not being able to see what we are working with makes it much harder to help you. And finding a schematic will be next to impossible, especially for small stuff like this. In fact, it's hard to get a schematic for anything other than TVs, amplifiers, laptops, and appliances these days.
So we really are better off with seeing whatever pics you provide us than trying to look for a non-existent schematic.
Old 09-11-2017, 06:43 AM   #7
lcdcaps1
hi
i was not running it without the caps
just turned it on for a second to see if all the lights flash or just some on bootup
but didnt so put them back
what could be stopping all the lights flashing ?
Old 09-11-2017, 07:55 PM   #8
momaka
momaka's Avatar
My Country: U.S.A.
That's more than enough time to do damage in some circuits. You don't test anything with components removed, even for a split second - not unless you know exactly what those components do in the circuit and you are sure the circuit will be alright without them.
So your router may or may not have been damaged by that. But I suppose we will see with further testing.
I don't know. Like I said, we need some pictures of your boards to see if we can point you to some component to check (i.e. voltage regulators, caps, etc.). Right now, I am completely in the dark and have no idea what to tell you to check. Perhaps see if you can connect to the router's login page over wired/ethernet connection even though the lights are not doing anything. (Of course, do that with the caps installed.)
But unless someone else has any different ideas, that's all I can give you for now.
Old 09-15-2017, 04:44 AM   #9
lcdcaps1
Managed to fix i
Thanks for everyone's help
Old 09-18-2017, 11:07 AM   #10
momaka
momaka's Avatar
My Country: U.S.A.
So what was wrong, in case anyone else runs into this?
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Badcaps.net Technical Forums 2003 - 2018
Powered by vBulletin ®
Copyright ©2000 - 2018, Jelsoft Enterprises Ltd.
