So I grabbed cheap HP 2509m off craigslist that exhibits a flashing screen (much like if your refresh rate is set incorrectly).
Everything displays perfectly, however it....flashes....as though the backlight is pulsing between medium brightness and high brightness. Sometimes when I turn it on, it actually corrects itself after a few seconds and works perfectly.
Now, I bought this with the intent to open it up and attempt to repair it. It is a sunk cost, and if I break it further I am not concerned. I bought it to tinker with. My question to the master tinkerers is- where do I start? My initial idea was to open it up and check all the caps. However, I saw in the menu that the monitor only has 3800 hours on it. I am not positive, but that does not seem to be too many?
Any ideas you can throw into the pot would be greatly appreciated!
I am uploading a video right now, should be live in a few minutes-
http://youtu.be/0o58ZdAr42k
Pics of the internal boards-
http://imgur.com/a/u03sv
PS- I can attach pictures to the thread instead if required, I just figured this would allow for higher resolution ones without clogging up the forum.
