Hi. When I turn on my tv it will be fine for a few minutes or sometimes up to 20 minutes but then it starts to flicker then eventually the screen goes black but I can still hear the sound just find. I opened up the back of the tv to see if I can visually see any bad caps but nothing. Could anybody possibly know what may be causing this problem. Thanks in advance.
vizio vw42l flickers
Re: vizio vw42l flickers
http://*************/photo/my-images...101122653.jpg/
If you need a better picture just let me know. This is from my phone.
Do you have a DMM?
Set your meter to 500VDC, 600VDC or 1000VDC (if it is manually ranging) or DCV if it is auto ranging.
Red probe in Volts/Ohm, black probe in COM.
Probe across that "Rubycon" 450V capacitor.
Careful -- high voltage. Do not short anything out.
Report reading. I am expecting around 390~400V if it is working. You need to measure it both with the set working and with it flickering.Last edited by tom66; 01-01-2013, 12:53 PM.Please do not PM me with questions! Questions via PM will not be answered. Post on the forums instead!
OK before i attempt this i have a couple questions.
Does this tv have to powered on for this?
Probe across means exactly what?
Do not want to tear anything up lol. Thanks for your help.
Sorry i forgot to say i do have a dmmLast edited by pposey; 01-01-2013, 01:05 PM.
Yes, the TV should be switched on.
We need a reading made while the TV is running (and working fine) and one while it is flickering (going wrong)
Also how frequent is the flickering... once it starts, every few seconds or many times a second? Does it start happening once in a while and then get worse, or does it suddenly occur?Please do not PM me with questions! Questions via PM will not be answered. Post on the forums instead!
I have encountered a bad 450V cap causing that very symptom. Though it degraded to the point of only having half the LCD dimly lit (after flickering badly), before going out completely on mine.Please do not PM me with questions! Questions via PM will not be answered. Post on the forums instead!
Rubycon are reliable, well made caps though, but it is always a good idea to consider the possiblity.Please do not PM me with questions! Questions via PM will not be answered. Post on the forums instead!
You need to do it while it is flickering. When the TV is in standby, it will measure 160~170VDC, and when it is off, it will measure nearly 0V. (It's not like a battery, will drain very fast when there is no input power.)Please do not PM me with questions! Questions via PM will not be answered. Post on the forums instead!
I did not realise this... I thought the backlight was what was flickering.
Can you try re-seating the video cable going from the main board to the T-con board while it is flickering and see if it resolves the issue. Try both ends if possible.Please do not PM me with questions! Questions via PM will not be answered. Post on the forums instead!
