Sony MBX 247 Laptop Dead. Need help ( Pics attached )
    Re: Sony MBX 247 Laptop Dead. Need help ( Pics attached )
    Originally posted by IamPritesh View Post
    What I noticed is that that on one side of PR290 I now have 19V ( VIN) and the other side it has around 6.5 volt. Is that normal ?
    Should be half of voltages of VIN
    I replaced the 1M resistor (PR290) and now we have 15VPCU showing correct voltage of 15V
    Good news..
    Have you check PGOOD1 after 15VPCU get normal?
    Also we need to know about RTC_RST# and SRTC_RST# and ACIN.
      Good news..
      Yes i think we are progressing in the right direction
      NO PGOOD1 yet because there is no MAIND signal to power the EC with +3V
        Interesting. In that case why PR272 shows 19V on VIN side and on the other side it shows no voltage after adapter is plugged in.
        ACIN voltage is 3.3
          Also what should be the ideal voltages on gate of PQ67 and and PIN2 of PQ68 before the power button is pressed.
          I also want to thank you for supporting me this far. You all are amazing.
            Would appreciate if you anyone can share their valuable inputs when they have some time.
              Actually didn't know power sequence on this model (HK1) a bit different with HK8 (mostly come to my bench) S5_ON signal turn ON after pressing PwrBTN. While HK1 seem S5_ON turn ON (actually on your board) after plugin adapter.
              What I've been thought that First EC need supplied by 3.3V, for purpose this only need EN2 ON and OUT2 present. Meanwhile EN1 (S5_ON) delayed or after by Pressing PwrBTN, this could be happen. Even if bios didn't supplied by 3V providing that EC got supply it could be. If HK1 should be like this, so S5_ON seem this signal premature.
              Found Power of sequence but don't know is correct or not.
                A pair resistor as voltage divider, then the value Gate PQ67 should be 8-9V, this in state DISCHARGE. (all voltages S3-S0 discharge)
                  The gate of PQ67 is 6.5 volt.
                    Yes S5_ON has 3.3 volt as soon as adpater is plugged in.
                    PR272 shows 19V on VIN side and on the other side it shows no voltage after adapter is plugged in. Is that normal ? RVCCD does generate just fine.
                      Anyone has any suggestion as what should I check next. I think we have progressed well so far after we have achieved 15VPCU.
                      Wondering why Pgood1 is not generated on PU9
                      Thanks.
                        I don`t see you mention about RTC...post#81.
                        What about VCC_POR# pin 85 NPCE?
                          Thanks.
                          For the PGOOD1 test the pin 11 of PU9 Voltage(2.5V)? + test PR148/150 , this is the feedback of 5V to PU9
                            I noticed that 3V was generating fine but 5V was not generating as it should. The output of COIL PL14 had 5V but the input side showed no voltage. 3.3 volt was generating just fine.
                            I tried replacing the PU9 IC and now I dont even have the 3.3 volt. What could have gone wrong ?
                              may be bad soldering test vin
                              pin 6
                              pin 7 LDO
                              pin 32
                              pin 3
                              pin 19
                                pin 6
                                pin 7 LDO
                                pin 32
                                pin 3
                                pin 19
                                yeah it was indeed bad soldering but now I have resoldered it almost pretty good but no luck.
                                Pin 6 - 19V
                                Pin 4 - 5.5
                                Other pins have no voltage.
                                Have I damaged this IC due to bad soldering?
                                  • +3V_SPI come from +3V_S5 via R61 (short pad), When PQ44 ON require trigger from RVCCD (approx 12V).
                                  • S5_ON generated 15VPCU be RVCCD.
                                  • Maybe bios not working had effect KBC not work well.
                                  thanks
                                    Please help . I also have the same board and am not understanding the meaning of 15vpcu.. Please explain to me coz am missing 5v rail only having 2.4v
