Badcaps.net Forum
Go Back   Badcaps Forums > General Topics > General Capacitor Questions & Issues
Thread Tools Display Modes
Old 08-03-2017, 05:44 AM   #21
Wayno
City & State: Durban
My Country: South Africa
I'm a: Knowledge Seeker
Default Re: Which Metallized Polypropylene Film Capacitor Should i use ?
I would just like to see that they looked like completed,instead of the yellow caps.
Don't stress was only asking a question.
Wayno is offline   Reply With Quote
Old 08-03-2017, 06:21 AM   #22
Wayno
Sorry all for Hijacking this thread, would this be the correct cap for the smaller of the two.
http://za.rs-online.com/web/p/polyes...itors/6225069/
I cannot see so well on my cellphone.
Old 08-03-2017, 06:32 AM   #23
Per Hansson
Per Hansson's Avatar
City & State: ----
My Country: Sweden
Line Voltage: 230v 50Hz
Didn't mean to come off as an asshole, sorry
I think the ones he used are these:
http://za.rs-online.com/web/p/polyes...itors/6225075/
This should also be a nice replacement, being X2 classed:
http://za.rs-online.com/web/p/polyes...itors/8740829/
http://za.rs-online.com/web/p/polyes...itors/8740826/
__________________
Per Hansson is offline   Reply With Quote
Old 08-03-2017, 01:36 PM   #24
Wayno
Thank you so much for your help.
Will get the better ones and try it out.
I am a real newbie to this stuff, agents and tecsa want nearly R3000 for a new PC board. If the replacement of the capacitors work like it did for RickyZa, then it saves me huge.
Old 08-03-2017, 02:06 PM   #25
Per Hansson
City & State: ----
My Country: Sweden
Be sure to order replacements for the electrolytic caps as well!
Old 08-03-2017, 03:54 PM   #26
redwire
City & State: Alberta
My Country: Canada
Default Re: Whirlpool WRF40 fridge Metallized Polypropylene Film Capacitor Replacements?
C9: 470uF 10V? electrolytic (P=?mm)
C5: 100uF ??V electrolytic (P=?mm)
C4: 1,000uF 10V electrolytic (P=?mm)
C10 - 0.47uF 250VAC metal film (P=22.5mm)
C11 - 1uF 250VAC metal film (P=22.5mm or 27.5mm)
If you can check/update the some of these numbers to help others.
I put these in from the pictures
redwire is offline   Reply With Quote
Old 08-07-2017, 05:21 AM   #27
Wayno
I am planning to take the board out tomorrow to work on replacing the Capacitors.
@ Redwire, I will update the numbers for you when I remove the capacitors, probably later tomorrow.
Old 08-16-2017, 02:09 PM   #28
RickyZA
RickyZA's Avatar
City & State: Western-Cape
My Country: South-Africa
Hey guys, i see things have been happening over here, i need to configure my notifications as i got nothing.
In anycase the Panasonic caps you posted are the exact ones i ordered Hanson, i just double checked and stock numbers are indeed the same.
Wayno did you manage to solder those new caps back on ? If not i can find the pictures i took of the finished job, they somewhere although its really simple, they bipolar ofcourse so you can mount them anyway you like.
Did you manage successfully actually getting the top cover off and getting the actual pcb out ? Thats a bit tricky.
RickyZA is offline   Reply With Quote
Old 08-16-2017, 02:16 PM   #29
RickyZA
RickyZA's Avatar
They are insane, i mean for such a simple board ... You get brand new Defy's that are the same size for R4500 these days. This should work for you especially if you have the same problem as i mentioned in the post. Let me know if you need any other help !
Old 08-22-2017, 01:34 PM   #30
Wayno
Hi RickyZA,
No I haven't had a chance been putting it off for a while, just moved house and trying to sort out chaos.
The top cover is a bit tricky and I wanted to spend more time in it so I don't break any plastic clips. Any pointers?
Old 06-13-2018, 06:53 AM   #31
Wayno
Hi Redwire,
Eventually I repaired my fridge. I changed all the caps. All is working perfectly.
Update - C5: 100uF 35V electrolytic
Old 02-25-2019, 11:18 AM   #32
parbhoos
City & State: UAE
My Country: Dubai
Unhappy Re: Which Metallized Polypropylene Film Capacitor Should i use ?
Hey guys just an update, i installed the two capacitors the ones that i linked in the post when i quoted Red and the fridge is back! all settings are working! i havent replaced the electrolytic capacitors just yet, not really keen to tinker more if i dont have to, what do you guys think should i replace them now ?
To anybody else viewing this thread this fridge is a Whirlpool WRF40, i should of put this in the topic but hey maybe this post helps you pick it up : )
Hi RickyZA
HELPP!!\
My fridge is on 1 led
Need your help please , what parts did you change and where can I buy them in SA ? parbhoos@yahoo.com
parbhoos is offline   Reply With Quote
Old 03-04-2019, 09:03 PM   #33
budm
budm's Avatar
City & State: S.F. Bay area
My Country: USA
Line Voltage: 120V 60Hz
See post #14, he replaced the two film caps. one is 1uF 250 VAC, another one is 0.47uf 250VAC.
Panasonic ECQUL series:
https://za.rs-online.com/web/p/products/6225075/
https://za.rs-online.com/web/p/polye...itors/6225069/
__________________
budm is offline   Reply With Quote
Old 03-05-2019, 12:52 AM   #34
parbhoos
City & State: UAE
My Country: Dubai
Hi Guys
Thank you for your posts and support and special thanx to Deon van Vuuren <deon@electro-web.co.za> for his reply
The fridge now works on ALL settings just like the first day we got it 15yrs AGO
Old 05-21-2019, 02:28 PM   #35
algrey
City & State: Hillcrest
Thanks guys been looking for a solution to this problem on My Whirlpool for about 12 months now. I'm going to order the caps right now and change them.
This will save me a new fridge as mine is now only working on one LED.
algrey is offline   Reply With Quote
Old 05-22-2019, 11:23 AM   #36
Retro-Hipster
Tinkerer
Retro-Hipster's Avatar
City & State: Salt Lake City
My Country: United States
Line Voltage: 120VAC 60Hz
I'm a: Hobbyist Tech
A note on why those Poly caps actually might be failing. On dropper circuits you can run into an issue where the "Self healing" nature of the capacitors essentially removes/damages the metalization on the film. When I say "self healing" I mean that things like high voltage spikes can cause small perforations. The metalization on the film blows clear which keeps the cap from shorting out. We are starting to see more and more of these types of failures on devices that use poly caps for capacitive droppers/dividers. The symptoms of this sort of failure tend to be a large decrease in capacitance instead of shorts.
You guys don't have to do this, but it would be pretty interesting to know if it is indeed that the capacitance has gone down. If you open up the capacitor, ones that have failed in this matter tend to look mottled and appear to have an almost "receding" sort of metalization on the film instead of sharp/shiny/clean looking.
__________________
“Men always seem to think about their
past before they die, as though they were
frantically searching for proof that they
truly lived.”
– Jet (Cowboy Bebop) -
Retro-Hipster is offline   Reply With Quote
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Badcaps.net Technical Forums © 2003 - 2019
Powered by vBulletin ®
Copyright ©2000 - 2019, Jelsoft Enterprises Ltd.
