Need BIOS for HP 15s-eq1060nq
    please I need a working BIOS bin file for HP 15s-eq1060nq motherboard DA0P5MB26A0 REV. A
    Thank you.
    all donations are welcome,
    Re: Need BIOS for HP 15s-eq1060nq
    Thank you.
    post the backup copy of the original laptop bios
      here is my problem: I read the chipset BIOS with CH341A software and AsProgrammer and I compared both files with HxD and there are not similar. The chipset is 1.8V W25Q128FW, maybe you can indicate me a reliable software to read the chipset, thank you.
        try this too..remove the bios chip from the motherboard before reading or writing..or solder wires between the legs of the bios chip and the programmer
        https://www.badcaps.net/forum/showpo...04&postcount=7
          I always remove BIOS chipsets and use an adapter to read/write. Anyway, here are the files, thank you in advance.
            ...wires between the legs...
            18+
            Become a Badcaps supporter
            Thanks to all supporters.
              try..
                try..
                I did try bin file you sent me, didn't work - same result: caps lock led blinks 5times long then 3 times short.
                I did try NeoProg, the result is the same as the bin file got with AsProg.
                Thank you very much for your time and effort, I really apreciate it.
                  try..
                  Your bios is fine, the laptop works. I thank you
                    Thank you peste
                      I have a hp 15s-eq1060nq and it shows the message from picture below. The hp System BIOS Update utility doesn't work - winflash.exe won't start on any computer.
                      Any ideas ? If I post a dump of bios could you help me ?
                      https://ibb.co/jMjY8Sp
                        If you post the bios file + serial number + question you will save a #.
                          There you go. Dump + SN
                            HP 15s-eq1000 Laptop PC (183N3AV)
                              This won't work.
                              peste's bios is working. You will need to disable Manufacture Programming Mode with BCU HP and edit your SN, UUID etc.
