Imac 27" 2011 POwer supply
    Hi
    I've got a lot of power supply for Imac 27" model 614-0446 (or PA-211-02a), that don't work.
    No component blow, fuse good, 390V on primary caps.
    I've check no short on secondary, i've tried to change all capacitors on primary and secondary without success.
    I suppose a serial problem on these power supply, more than 10 pcs with same problem.
    Anyone can help me on this? Many thanks!
    Luke
    Re: Imac 27" 2011 POwer supply
    Most likely the PWM/SMPS IC and/or the Transformer start up circuit has some open resistors
