This is really weird.
When I got this board, it had OSTs on the VRM inputs and UCC KZJs on the outputs. I replaced the OSTs with Ruby MBZ.
Installed it with a A64 3400+ (venice) and a X800.
After the first install the board didn't do anything - no POST, no beep codes (but fans were spinning). When I removed the graphics card however, I got the 1x short - 2x long beep code which means missing vga card or vga error.
After a few tries and reconnecting all the cables and connectors I took the MB out of the case and set it up on my desk.
It POSTed at the first powerup, everything seemed fine. Checked the board and case for things or solder residue that might have caused a short, but found nothing.
I reinstalled the whole (basic) setup in the case, fired it up again and installed XP64, did a BIOS update and started to install all the drivers.
When I installed the audio drivers (Audigy 2ZS +SB Live), the system suddenly rebooted. I tried a few fore times, it always did a reboot at the same point.
I removed one of the cards and hit the power button again, but - nothing. Basically like after the first install. Took it out of the case again, but nothing happened. It didn't even beep with the VGA removed any more. (but fans still running)
My first suspect was the PSU. I admit it's a crappy one ("420"W eSAC, also known as Advance), but I recapped it some time ago and so far it had run stable with my XP3000+ (which doesn't draw much less than the Venice), and it's running fine right now.
I checked with the DMM when it was hooked up to the mobo, and PSU and VRM output voltages were normal.
Unfortunately I don't have a port80 dongle as I've used Epox over the last few years.
This doesn't make much sense to me... It's not too strange that a mobo doesn't work at the first try, but it ran fine for an hour or two; is it just coincidence that it failed at the driver installation?
TiA,
kikkoman
TiA,
kikkoman
