Power supply build quality pictorial.closed.use part 2
This topic is closed.
This is a sticky topic.
    Re: Power supply build quality pictorial
    already posted in the discussion thread...
    noname PSU rated for "520" watt (partly disassembled, but anyways...)
    http://bambooz.pytalhost.net/WHF/Bil.../520Watt_1.jpg
    http://bambooz.pytalhost.net/WHF/Bil...520Watt__2.jpg
    350ATX ...?! smells *really* fishy.. and thats probably the peak wattage this POS can do..
    http://bambooz.pytalhost.net/WHF/Bil...520Watt__3.jpg
    Zhifa? Zhila? Zhi.... whatever..
    http://bambooz.pytalhost.net/WHF/Bil...520Watt__4.jpg
    this thing already went into the trashcan..
    i wouldn't even use this thing any of my old Pentium 3 PCs.. lol
    for the records: that UL number on the label leads to L & C Power according to jonnygurus database..
    L & C TECHNOLOGY INC
    E164554
    L&C, Apex/Allied, Austin, Deer. NOT to be confused with "LC-Power"
    see here:
    http://www.jonnyguru.com/modules.php...ory&ndar_id=24
    UL Number: E164554
    edit: looking at the label again.. that german part is just horrible..
    they used AOU instead of ÄÖÜ and it should be Kundendienst instead of Kundndienst.. lol
    looking at those "caps"... "LOW 105°C" ...!?
      Not too bad for 200-250 watts tops, of course if it had nice caps and filtering. But it seems ridiculously overrated for 520w.
      Still, though, you shouldn't throw it in the trash can. They put out a lot of bad contaminants in groundwaters, even at good disposal sites.
        Wow! now that's a GUTLESS WONDER!
        4 diodes, missing parts, mis-spelt stuff, a "rip-off" name in the mix, caps of questionable heritage and a gross over-rating!
        Who needs an input filter anyways?
        Oh! but where are the dummy weights?
        But... it's ROHS certified! That should be plenty safe!
        Off to the Dentist
        Keri
        The More You Learn The Less You Know!
          A real pos: no regret in throwing it in your town's recycling area. As PCBONEZ pointed out, don't pollute the ground with such a crap.
          Zandrax
          Have an happy life.
            Antec True380 380watt ATX PSU
            Bad Fuhhhjjjweruuyyyyuuu's
            The Panny mains almost feel a little bulged, but it could just be a fluke.
            Three more bad Fujjhuurrrrkkuu's
            Way too much flux residue... bad solder
            Closer... looks nasty.
            All better.
            Took me the better part of an hour to get it completely recapped and resoldered.
            Ludicrous gibs!
              Young Year 350W ATX PSU
              The label
              Top View
              Tiny lil' thing eh?
              Yellow caps of some sort. The picture's kinda poor but most of the caps are leaking.
              Big caps. I have no idea what brand they are.
              This PSU's wires are 20AWG and fairly short.
              It's extremely light and it's casing is extremely bendable. I've warped the casing beyond repair just by opening this thing lol.
              The absence of a fan is because I ripped it out and used it for something else. This PSU has never been turned on without it's fan though.
              It's fan is an 80mm Yate Loon Sleeve bearing fan "D802SM-12"
              Fairly loud.
              For those wondering, this thing still "works". It was used for 5 1/2 years without any noticeable trouble.
              I can't imagine how unstable the voltages and ripple were though.
                Fortron Blue Storm 350W
                Fortron FSP350-60THN-P (Blue Storm 350 with PFC)
                Protechnic Electric MGA12012MS-O25 0.38A fan
                OST 820uF 200V (SPS, 85C)
                Teapo 4700uF 10V
                Teapo 2200uF 16V
                CapXon 1000uF 35V
                Jamicon 3300uF 10V (TM)
                  Fortron ATX-400PNF
                  FSP ATX-400PNF
                  Yate Loon D12HS-12 0.30A fan
                  Teapo 820uF 200V
                  Teapo 2200uF 16V
                  Teapo 3300uF 10V
                  Mostly Teapo's inside, several OST.
                    Antec SL220P
                    Antec SL220P
                    PSU from Antec Minuet case after about 4 years of use.
                    Xinruilian RDM8015S (80x80x15mm) fan is stuck, high capacity Fuhjyyu and Teapo caps bulging. Considering it's price, quality of Antec PSU is
                    Fuhjyyu 68uF 400V (?)
                    Fuhjyyu 2200uF 10V
                    Fuhjyyu 2200uF 16V
                    Teapo 3300uF 6.3V
                      Originally posted by yanz
                      Delta DPS-125EB-1 120W PSU
                      (or, DPS-125EP-1 <- on the PCB)
                      thumbnails:
                      Thats the same PSU that was in my HP Vectra vl600 i use to have. It popped in my computer, but the little connector on it was for a internal backup battery the computers could have that went in one of the 5 1/4 bays.
                        FSP200-601U
                        A colleague gave me this slim PSU, 200W 2 FAN and Teapo caps.
                        Ciao
                        Gianni
                        "In the confrontation between the stream and the rock, the stream always wins...Not through strength, but through persistence."
                        H. J. Brown
                          This afternoon I found some good stuff at the industrial waste near my office: one LCD panel, one board full with Rubycon ZL caps, one full with unknown Sanyo caps and a DPS125EB PSU made by Delta.
                          Ciao
                          Gianni
                          H. J. Brown
                            Me and other parents are helping our children's school to renew the computer room.
                            One parent gave me a Techsolo PSU and said it is working but sometime gives problem with the mouse
                            I opened it and found a lot of bulging caps. Some caps brand are new to me: Jenpo and Lowes.
                            The PSU looks nice, it is blue and it is a modular type but I'm wondering if it is worth to recap it because I don't think it can give 400W
                            I want to use it with a AK77 MOBO I'm going to recap, tomorrow I will post some pics of it.
                            Ciao
                            Gianni
                            H. J. Brown
                              I'd like to see the whole pcb: heatsinks are substantial, cables seem average (AVG 18?), sloppy soldering and bad caps. Don't know if pfc is present, I doubt anyway, but if the rectifier is a mosfet and not the cheap 4 diode pack and the emi filter hosts all pieces then I'd keep it: an honest 250-300 W which is good for your Athlon system.
                              Zandrax
                              Have an happy life.
                                HP dc7800CMT / LiteOn PS-6361-02
                                HP dc7800 CMT PSU / LiteOn PS-6361-02HP-ROHS
                                ADDA AD0912US-A70GL fan
                                Elite 330uF 450V
                                OST RLS 1200uF 16V
                                United Chemicon RLS 2200uF 6,3V
                                Inside mostly OST and United Chemicon (difficult to view).
                                  Samsung 153V , power supply board
                                  the monitor I used for 4 years
                                  It would flicker for a while , somtimes when I turned it on .
                                  I replaced the capxon with some rubycon ZL & KZG solved the problem
                                    Dell 1504FP LCD with a FSP-041-3PI01 power supply board. The monitor goes dark because one of the back light transformers is bad. The custom wound Sparkle Power SPI 8TT00006 transformer with the (X) on it needs replacement.
                                    The board revision is different. The date code moved. A logo below the date code changed. Several parts in the PWM have been changed or moved.
                                    I don't think I've ever seen a board other than this one that fuses both incoming lines which definitely makes sense for 220v operation.
                                    sig files are for morons
                                      PowMax LP-7700D 350 watts(?) ran in one of my computers six years - never failed but pulled when I found out about PowMax quality!
                                      Old proverb say.........If you shoot at nothing, you will hit nothing (George Henry 10-14-11)
                                        Xtreme LP-6100 400 watts(?) - looks a lot like PowMax (works)
                                          Raptor LC-B400ATX 400 watts(?) 2 bad 1000uF caps replaced and 2 diodes in bridge were shorted, replaced with a one piece bridge rectifier - probably another PowMax class power supply
