Hello everyone
I'm back with another ATX that doesn't want to leave, with the experience of technoware I did the same tests you recommended me, the structure is very similar, on the primary the voltage on the large capacitors is good, I tried the voltage on the transformer small and I have 5,7 volts, I have 5v standby, I have 8,5 volts on pin 12 of the integrated circuit, the mosfets on the primary and the shottky diodes on the secondary are fine, when I turn on the power supply I have about 6 volts for a few seconds on the line of 12 volts which then vanishes on 5 volts nothing and not even on 3,3
