lenovo 320 nm-242 touch pad not working
    hello i have lenovo ideapad 330 borad numb nm-242 touch pad not working
    i did try install new windows update bios update driver nothing work and when u
    take look at device manager i see yellow triangle on **i2c hid ** code errror i did install all the driver nothing is missing and when u try f6 nothing happaen
    10
    any suggestion 3v present
    Re: lenovo 320 nm-242 touch pad not working
    try to plug a windows install flash drive and see if it work in that environment
      does not work
        this is the problem
          Originally posted by nabilgo View Post
          this is the problem
          any one,,,?????
            Try these drivers
            Intel serial IO driver
            https://download.lenovo.com/consumer...s/9u0d03af.exe
            Touchpad drivers
            https://download.lenovo.com/consumer...st08af09mc.exe
              Go to device manager and under "view" allow it to show old drivers.Get rid of old drivers. Get rid of (uninstall) them all.
              Good luck.
                Better yet, download a portable called device cleanup tool and run as administrator. Remove everything that shows up.
                  Originally posted by SMDFlea View Post
                  didnt work bro i think it a hardware probleme
                    check the picture
                      any oen pls
