Can Any One Tell My What The Benefit Of This Component (pq17) Becouse The Motherboard Was No Power And The (ACDET) Hase 0 Volt But When I Remove It The (ACDET) Hase 2.6 Volt And The Motherboard Is Working Ok.
Acer Aspire A315-55 No Power(Strange Fault)
Re: Acer Aspire A315-55 No Power(Strange Fault)
PQ17 is biased on by the voltage divider PR230/PR235, so will short out the ACDET pin to the BQ24780 to ground (which will turn off your input FETS). ADP_ID is connected to the gate and the charging jack, and would need to drive the gate of PQ17 off to enable charging.
So I surmise that a genuine Acer charger will short this to ground (or have a low resistance value to ground) in order to charge. So check the DC Jack itself and the charger, particalarly if it's an aftermarket one. This is just a simplistic way of disabling charging if a non-genuine charger is used.
Originally posted by reformatt View PostPQ17 is biased on by the voltage divider PR230/PR235, so will short out the ACDET pin to the BQ24780 to ground (which will turn off your input FETS). ADP_ID is connected to the gate and the charging jack, and would need to drive the gate of PQ17 off to enable charging.
anyway I Remove It And The Laptop Working Fine. Thanks For Help.
