my s3 mini wont turn on
    hi friend my s3 mini wont turn on any solution ?
    do you have some schematic ? my battery is 3.2v is it ok to turn on the phone?
    thanx
    Re: my s3 mini wont turn on
    3.2V is not enough, you need at least 3.4V IIRC. Nominal voltage is 3.8V and a fully charged battery should be a bit above 4V.
      hi ok thanx a lot for confirmation so how can i charge it by pass to see if the problem is the charger port or the battery it self because i change charger but same problem
        hello,
        the easiest way is to check if you get ~4.2v(while charging) on the pins where battery is connecting(for that you need multimeter) . If you get it, means that the route from charging port to the battery is ok. Battery itself should not go above 3.7v (if on the battery is written 3.7v) even when is fully charged. More then that means battery is not good.
          hi and thanx for reply but how can i check charging by multimeter un put two wires from multimeter and charging by usb port?
          regards
            easiest way is to plug it into a usb monitor.
            battery that low may be in pre charge.about 50ma.
            there will be no signs of life till it goes to full charging current.
            then it will go to startup then battery level.
            if you dont see any current draw on the monitor look at the usb jack.
            i replace them all the time.
            full charge voltage is 4.35v
            http://www.ebay.com/itm/DROK-USB-2-0...3520548http://
              hi friend thanx a lot for your help your link is not working
              what do you call usb monitor
              sorry i m beginner if you have some picture or video to understand
              thanx a lot for help
                Something like this.
                http://www.ebay.co.uk/itm/LCD-USB-De...-/292076965244
                  this is the one i have got
                  https://www.youtube.com/watch?v=oANNq7Q83f4
                    hi guys thanx a lot for sharing i understood now for checking
                      i im waiting for usb monitor and i will try the test ...
                      to be continued
                      regards
