Re: HP laptop with no power. Can you help me understand the shematics?
Make sure you discharge the gate when testing if it's OFF. You can do so by shorting gate to source or inverting the probes of the meter (positive on source, negative on gate. When you short gate and source it should definitely be open. And you can do the diode test also as suggested before. From source to drain will show you the bodydiode.
Originally posted by mattpd
View Post
