Dell INspiron 3580 EDI54 LA-G712p rev 1.0(a00)
    Re: Dell INspiron 3580 EDI54 LA-G712p rev 1.0(a00)
    Thank you let me try it....
      Originally posted by shabi View Post
      its a new file
      same results... = no Display ..
        or maybe someone can help with a Clean ME region on my backup..
          The one at post #2 has clean ME FW. Theres more on the forum with clean ME FW , the same bios is used in these models: Inspiron 3480 3580 3583 3780 Vostro 3480 3580 3583.
          Try the attached bios, if it doesn`t work the problem is somewhere else.
          It doesn`t matter if the ME FW is a bit older,newer or exactly the same as long as its configured - clean.
            will try it now sir ..
            thank you...
              Any one know where I can find a Schematic diagram or board view for this..
                The bios and schematic request forums are seperate.Make your request here:
                https://www.badcaps.net/forum/forumdisplay.php?f=41
                  no schematic or boardview LA-G721P available
                    It works...Thanks a lot
                      100% ok
                      thanks its working
                        can someone fix this bios for me? it is stuck and trying to do a recovery but it fails all the time.
                        I tried more than 7 bios but only one works which shows as inspiron 3780 and it doesnt read the m.2 ssd.
                        My Model
                        Inspiron 3583
                        EDI73 LA-G711P
                        REV 1.0(A00)
                        2018-11-05
                        let me know if someone can fix it or provide me with a working one.
                        Thank you in advance
                          Finally i found one working properly. i will post it if someone need it.
                          TESTED OK
                            Re: Dell latitude 3190 Suffix E7A8 Bios Password Request
                            Hello guys I bought a laptop from a friend and it has a admin password which the last owner forgot I need a master password it's a dell insprion 3583 I've tried bios-pw.org but the password doesn't work my system number is 9YQ06Z2-E7A8 thanks in advance
                              @Storm758
                              Try the first password, if that doesn't work, use the second password.
                              PASSWORD #1
                              DELL Service Tag: 9YQ06Z2-E7A8
                              password: 57ZPWM1nk2JM30xE
                              PASSWORD #2
                              password: ZR8G2ybsk8ksZeXr
                              Type the 16-character password. For UPPERCASE characters use SHIFT key.
                              Once you are done typing password, hold down left CTRL key and press ENTER key *twice* (CTRL-ENTER-ENTER).
                                Hey I just want to show my gratitude it worked thanks alot buddy I've been trying to get unlock this bios for months man you guys are awesome I should have join this forum ages ago bless you man
                                  Welcome!
                                    thanks. it worked
                                      board: EDI73 LA-G711P REV 1.0 (A00) 2018-11-05
                                      Service Tag: B58F1W2
                                      Express Service Code: 24261075794
                                      LAPTOP Inspiron 3480
                                      No display
                                        No display
                                        Try to clean the ME firmware first - https://www.badcaps.net/forum/showthread.php?t=103526 ,if that doesn`t work try one of the working bios in this thread.
                                          100% ok
                                          its working fine thanks bro
