Go Back   Badcaps Forums > Troubleshooting Hardware & Devices and Electronics Theory > Equipment Usage, Soldering, Techniques, and Reviews
Old 01-24-2019, 02:59 AM   #1
LENOVO-A880
Not A Bad BIOS
LENOVO-A880's Avatar
City & State: SELANGOR
My Country: MALAYSIA
Line Voltage: 240VAC 50Hz
I'm a: Hobbyist Tech
Default Conform Coatings Application On Motherboard /Circuit board
Hi Badcapers,
Would like to ask I'm having a few boards which some are memory modules PC100/PC133, motherboard from Acer Aspire V76M desktop system, wireless card and laptop memory modules which are not working properly likely due to minor shorts causing crashes on systems. Can any light conformal coatings usage in aerosol/spray mode be used on these circuits boards as a protective layer/film to prevent from dusty environment? What kind of brands available out there will be specialised for insulating boards against chemical or corrosive attack? THANK YOU..
"If you cannot do great things, do small things in a great way."
-Napoleon Hill
"The chip that functions abnormally will be desoldered, as they say."
-Charles Stross
"Why is it you're always too small or too tall?"
-The Mad Hatter
LENOVO-A880 is offline   Reply With Quote
Old 01-25-2019, 03:45 AM   #2
llonen
City & State: united kingdom
My Country: hampshire
Line Voltage: 240 VAC 50Hz / 110 VAC 50 Hz and 415 VAC 50Hz
Default Re: Conform Coatings Application On Motherboard /Circuit board
The boards you describe will come with a con-formal coating already applied to protect the printed circuits and related equipment from their environment, that said if you have had to remove any of the coating to effect repairs then I have found Electrolube products quite useful in the past. In particular their Acrylic Coating and for better protection maybe Polyurethane Coating both can be obtained in aerosol form, KEEP the stuff away from and DO NOT APPLY to any bare or plated contacts such as edge line connectors or sockets for obvious reasons.
llonen is offline   Reply With Quote
Old 02-01-2019, 06:22 AM   #3
LENOVO-A880
Not A Bad BIOS
Originally Posted by llonen View Post
...that said if you have had to remove any of the coating to effect repairs then I have found Electrolube products quite useful in the past...
Will it be truly necessary to completely remove the existing coat on these memory module before even applying the new acrylic coat. What will happen if I don't remove the coatings as I don't have the necessary tools to do it?
Old 02-01-2019, 06:48 PM   #4
llonen
I am not sure what you are trying to achieve here, if the con-formal coating is intact and you have not removed any of the material to effect repairs I am not sure why you would need to add another layer.
Old 02-02-2019, 05:32 AM   #5
Sparkey55
City & State: OK
Originally Posted by LENOVO-A880 View Post
Hi Badcapers,
I am assuming that you have your computer equipment in a wet humid enviroment. Try keeping it in a room with plenty of cool air circulating so as moisture does not cause a problem. The best method to keep electrical contacts clean and rid of moisture in the air is to use a product similar to DeOxit D5 or ProGold. Must be safe to use on electronics.
Sparkey55 is offline   Reply With Quote
