Old 01-23-2019, 04:30 PM   #1
capwizard
capwizard's Avatar
City & State: Arizona
Default 47ls4500 screen has rainbow color.
47LS4500 screen has rainbow colors or solarized distorted picture.
I've changed T con still the same.... rainbow color. should I order the main board or just give up and they want me fix tomorrow or tv just needs reconfiguration.
capwizard is offline   Reply With Quote
Old 01-23-2019, 04:50 PM   #2
petehall347
City & State: worcester
My Country: United Kingdom
Default Re: 47ls4500 screen has rainbow color.
try turning colour and contrast down . might not help but worked once for me with a pc monitor
Old 01-23-2019, 05:40 PM   #3
capwizard
capwizard's Avatar
Thank you. tv really works. I probably just charge customer half the price. tv really improves a lot.
Maybe someone changed main board with different panel no?
Old 01-23-2019, 06:44 PM   #4
DXseekerMO
City & State: Linden Twp. Missouri
My Country: US
I had that exact same problem on a 55" Vizio E550i-B2 and it was the LVDS cable. I wiggled it and got a change of picture state. Removed it and the contacts were swayed. Replaced it with one from the parts pile and it worked great!
DXseekerMO is offline   Reply With Quote
Old 01-23-2019, 06:55 PM   #5
capwizard
capwizard's Avatar
thank you, i will try it tomorrow.
Old 01-23-2019, 07:01 PM   #6
petehall347
try less colour . match skin colour to reality .
Old 01-26-2019, 03:19 PM   #7
capwizard
capwizard's Avatar
Update
I've changhed LG main board and the t-con board so the problems are on the screen itself. thanks for everybody helped.
Old 01-26-2019, 03:40 PM   #8
budm
budm's Avatar
City & State: S.F. Bay area
Line Voltage: 120V 60Hz
I have never seen bad LCD panel that will cause bad GAMMA like that, you need to check GAMMA reference Voltages on the T-CON board.
Old 01-27-2019, 11:35 AM   #9
budwich
City & State: Kanata Ontario
My Country: Canada
you might want to get into the service menu and check things out there. Some settings may deal with panel settings such as the number of bits the panel supports along with the type of color system used. further, what inputs have you used / are available (ie. rgb, hdmi, composite).
budwich is offline   Reply With Quote
Old 01-27-2019, 11:51 AM   #10
capwizard
capwizard's Avatar
I've changed 4 main boards and 5 T con boards still are the same problems.
Old 01-27-2019, 11:56 AM   #11
capwizard
capwizard's Avatar
I tested with rf signal but it happened on manu also.
I've spend almost two days I still can't go into the service menu.
Old 01-27-2019, 12:23 PM   #12
R_J
City & State: ☻
My Country: Canada
You likely need the (@R$%^) service remote to access the service menu The remote has a [IN-START] button on it
R_J is offline   Reply With Quote
Old 01-27-2019, 12:50 PM   #13
vinceroger69
City & State: Nuneaton Warwickshire
My Country: uk
I'm a: Hobbyist Tech
Lg in start tv remote app
vinceroger69 is offline   Reply With Quote
Old 01-27-2019, 03:16 PM   #14
capwizard
capwizard's Avatar
How to Make an IR Blaster
https://www.instructables.com/id/How...an-IR-Blaster/
i did make an IR Blaster but my LG phone does not have On-The-Go (OTG) capability. i've down load the APP with an [IN-START] button but i cant use it.
Old 01-27-2019, 05:57 PM   #15
budwich
My Country: Canada
not sure about what the OTG capability gives you BUT basically all you need a "wav file" which you "play" that results in the proper "ir wav" when the "leds" are connected to your headset outputs on your phone / any phone.
Old 01-27-2019, 08:43 PM   #16
capwizard
capwizard's Avatar
vinceroger69 sent me the ZIP files, I didn't knew what was what, after your interpretation, i unzip the file, found the EZ_ADJ .wav IN_START.wav IN_STOP .wav POWER_ONLY.wav . i will try it tomorrow
Old 01-27-2019, 08:49 PM   #17
R_J
City & State: ☻
My Country: Canada
If you can get into the service menu with your phone, you should be able to use a regular lg remote after that to navigate the menu/settings
Old 01-28-2019, 12:08 PM   #18
capwizard
capwizard's Avatar
Thanks to all my friends.
I spend whole morning. I still cannot figure out how to do it. I even use Bluetooth hook up IR booster right into speaker. I ended up ordered a $5.84 service LG remote controller.
Old 01-28-2019, 12:17 PM   #19
Diah
City & State: SA
My Country: Germany
with wav. file need to make DIY IR LED and speaker or headphone jack. insert it at pc speaker out. then play the wav file with (Windows Amplifier ) player on pc windows.. only on this player the code will sent correctly as its
Diah is offline   Reply With Quote
Old 01-28-2019, 12:27 PM   #20
capwizard
capwizard's Avatar
Thank you, do you mean, I cannot use my cell phone connect to Bluetooth with the homemade IR booster connect right to the speaker.
I heard the pop noise at beginning then were the strings of code sounded.
