Old 01-23-2019, 09:42 AM   #1
123XYZ123
City & State: NN
My Country: NY
Default Toshiba satellite l500 defect VGA?
My toshiba has a black screen until the windows starts loading. So I cant see the booting nor enter the BIOS because I cant see what Im doing.
When I connect it to an external display, in this case my TV through a HDMI cable, it shows everything on the TV, including the booting and BIOS.
However, when I tried to connect my laptop to the TV through the VGA I didn't see anything on the TV, not even when the windows boots.
Can this be fixed and is it worth risking?
123XYZ123 is offline   Reply With Quote
Old 01-24-2019, 05:21 AM   #2
caspian
City & State: Mainboard
My Country: Laptop
I'm a: Hobbyist Tech
Default Re: Toshiba satellite l500 defect VGA?
it is probably the way your laptop was built. when was this issue started to happen?
caspian is offline   Reply With Quote
Old 01-24-2019, 06:42 AM   #3
123XYZ123
City & State: NN
My Country: NY
Maybe a month ago, when I wanted to boot my other windows but couldn't see the boot menu, I have kali linux on it too. Was working perfectly fine before.
I can see the boot menu and select the right system which I want to use while connected to an external display over HDMI as I mentioned.
Old 01-24-2019, 06:54 AM   #4
caspian
My Country: Laptop
remove the hdd from the laptop and test it again.
Old 01-24-2019, 07:00 AM   #5
123XYZ123
City & State: NN
My Country: NY
Same. But on the external display I can see it.
I tried it without the external display first ofc.
