Old 01-22-2019, 08:10 AM   #1
ktmmotocross
Boardkiller
ktmmotocross's Avatar
City & State: slovakia
My Country: slovakia
Line Voltage: 230VAC 50Hz
I'm a: Hobbyist Tech
Default Fujitsu LI3710 - no video after water spill
Hello.
Have this Fujitsu Amilo LI3710 that have some water spill on it and really bad burned LCD connector. LCD connector was burned only on 19V pins. When start it work only 2-3 seconds and shut down.
I clean some corrosion and removed burned connector. now it start and all voltages looks ok. right now i dont have connector replacement so i try to check it with external monitor, but have no video.
Is there a way to check why have no video or chceck if lcd signals is ok?
like with osciloscope or cut lcd cable and solder it directly to board
ktmmotocross is offline   Reply With Quote
Old 01-23-2019, 12:41 AM   #2
on/off
on/off's Avatar
City & State: Forbidden
My Country: Indonesia
Line Voltage: 220VAC 50Hz
Default Re: Fujitsu LI3710 - no video after water spill
Try lift R279, it's trick to force external display mode.
on/off is offline   Reply With Quote
