Go Back   Badcaps Forums > Troubleshooting Hardware & Devices and Electronics Theory > General Electronics Technical Discussion
Old 01-20-2019, 07:57 PM   #21
capwizard
capwizard's Avatar
City & State: Arizona
Default Re: What do you think about this meter Feedback need
you can view the waveform signal 20KHz within.............. i'll pass.
i will wait until they update bandwidth to 2MHZ or 20MHZ.
capwizard is offline   Reply With Quote
Old 01-21-2019, 07:49 PM   #22
llonen
City & State: united kingdom
My Country: hampshire
Line Voltage: 240 VAC 50Hz / 110 VAC 50 Hz and 415 VAC 50Hz
Yeah I don't get the point of that feature, its the sort of thing you can do with a laptop and free software using the sound card if I recall. Well assuming you have the aforementioned laptop, analogue scopes can be had very cheaply now as well.
llonen is offline   Reply With Quote
Old 01-22-2019, 07:52 AM   #23
stj
stj's Avatar
City & State: Europe
the point of the feature is to see if the power is stable, or if it's being effected by something.
it's actually very good in some situations.
Old 01-22-2019, 08:59 AM   #24
capwizard
capwizard's Avatar
Do you mean datalogging?
I would like to have my next meter with another future is data logging that's what I've been searching for a cheaper and easy to use one. Any suggestion?
Datalogging with a Multimeter
https://www.norwegiancreations.com/2...-a-multimeter/
Old 01-22-2019, 09:20 AM   #25
stj
stj's Avatar
no, not logging.
if you put a standard meter on a car supply, it will say 12-14v
but if you put a meter with a waveform display you can see if the alternator is failing because you can see the dips between the 3 phases.
dc is not always a flat-line, even if you want it to be!
btw, i have a 22000count meter with a serial port - it's not the same thing.
Old 01-22-2019, 10:00 AM   #26
capwizard
capwizard's Avatar
no, not logging.
This meter's waveform has 20KHZ bandwidth limitation. that means you cannot detect any high frequency noises it is good for low-frequency equipment like audio devices repair only. not even for switching power supply.
Old 01-22-2019, 04:16 PM   #27
sam_sam_sam
City & State: Sunny Jacksonville FL
Line Voltage: 120 Volts 60 HZ
In other words it would show you that you one or more diodes failing which would be very helpful determining if that was causing your battery to drain over night
But in general the output of an alternator is very noisy to being with any way but the wave form output would be different
9 PC LCD Monitor
6 LCD Flat Screen TV
10 Desk Top Power Supply
1 Dell Mother Board
15 Computer Power Supply
1 Over Head Crane Current Sensing Board
All of these had CAPs POOF
sam_sam_sam is offline   Reply With Quote
Old 01-22-2019, 08:31 PM   #28
stj
stj's Avatar
sort-of,
the alternator is a rectified (but not smoothed) 3phase generator.
the dips in the output should be evenly spaced, if not then a diode or winding may be bad.
