Go Back   Badcaps Forums > Troubleshooting Hardware & Devices and Electronics Theory > General Electronics Technical Discussion
Old 01-13-2019, 09:37 AM   #1
sam_sam_sam
City & State: Sunny Jacksonville FL
Line Voltage: 120 Volts 60 HZ
Default What do you think about this meter Feedback need
Here is the link for this meter
https://banggood.app.link/I36q2jINrT
9 PC LCD Monitor
6 LCD Flat Screen TV
1 Dell Mother Board
15 Computer Power Supply
All of these had CAPs POOF
sam_sam_sam is offline   Reply With Quote
Old 01-13-2019, 02:16 PM   #2
stj
stj's Avatar
City & State: Europe
Default Re: What do you think about this meter Feedback need
https://www.youtube.com/watch?v=KujMeU4QAvY
thought it looked familiar!
Old 01-13-2019, 05:32 PM   #3
sam_sam_sam
Thanks for sharing this link
From his review it is decent meter for what you are paying for
I have seen his reviews before
Old 01-13-2019, 06:13 PM   #4
stj
stj's Avatar
i wonder if the update is fast enough to see electrical noise on dc rails. ??
Old 01-13-2019, 06:15 PM   #5
stj
stj's Avatar
wow - look at this!
https://www.banggood.com/1000M-1000V...p-1182844.html
they are making retro-style test gear! i may have to have one!
Old 01-13-2019, 06:29 PM   #6
sam_sam_sam
Originally Posted by stj View Post
wow - look at this!
If you buy one and try and test can you please post the results
Old 01-13-2019, 06:32 PM   #7
petehall347
City & State: worcester
My Country: United Kingdom
wow - look at this!
i had a real one but my good friend is looking after it now .
petehall347 is online now   Reply With Quote
Old 01-13-2019, 06:36 PM   #8
stj
stj's Avatar
i dont know how to test one other than by blowing shit up!!
it just looks like a detonator for putting stuff across - like leds!!!
Old 01-13-2019, 06:41 PM   #9
petehall347
meggers arent for testing as much as for fixing picture tubes or so i was told .
Old 01-13-2019, 07:33 PM   #10
sam_sam_sam
The real use for one it check insulation break down in motors and any device that needs to be checked like that
Old 01-13-2019, 07:42 PM   #11
petehall347
yes indeed .. i believe a modern pat tester works plus more features too .
i could never find anyone to hold the probes whilst i turned the handle to make sure it was working .
Old 01-13-2019, 07:47 PM   #12
sam_sam_sam
If anyone know what it is and know how it works would not touch the leads while you winding it up
Old 01-13-2019, 09:37 PM   #13
stj
stj's Avatar
i have seen them now on ali with 2KV output,
but to do a legit pat test i think you need 5ma - have to check that.
in the end, you buy it for the retro/fear factor.
an electronic 1KV megger with 2Gohm range costs less!
Old 01-14-2019, 11:59 AM   #14
Stevie406
City & State: Wishaw
Line Voltage: 240VAC 50Hz
I have owned one of these DMMs for a few months now. It's a reasonable meter for the price, but some of the measurements take a little longer than expected to show the results. But it is pretty accurate.
I have just received this DMM (see link below) the other day, and it's much better.
Look at the spec for yourself. And the price is great also.
https://www.banggood.com/ANENG-AN870...?rmmds=myorder
Stevie406 is offline   Reply With Quote
Old 01-14-2019, 05:41 PM   #15
sam_sam_sam
This is type of meter that I am looking for thanks for the review
I have to many meter like this but maybe not a 19999 count it is on my wish list
Old 01-15-2019, 05:33 PM   #16
llonen
City & State: united kingdom
My Country: hampshire
Line Voltage: 240 VAC 50Hz / 110 VAC 50 Hz and 415 VAC 50Hz
Not one I would want, look around for a decent second hand Fluke some of the models can be had for similar amounts on the second hand market, well minus the scope(y) thing anyways.
llonen is offline   Reply With Quote
Old 01-15-2019, 06:24 PM   #17
stj
stj's Avatar
waveform display is what makes it usefull though.
if i was after a very safe meter i would skip fluke and get a Hioki btw.
Old 01-16-2019, 12:08 AM   #18
redwire
City & State: Alberta
My Country: Canada
Hioki has no electrical safety agency approvals, I would avoid them for that.
Typical of Japanese multimeters. They will claim EN61010 or Cat. III but no proof they were tested. Then you find a gas tube inside, not a MOV like Fluke and others, so I would not use that on mains stuff. Once a gas tube is lit, it's shorting your input.
Oscilloscope kit DSO138 is cheap and popular, I wonder if it outperforms this DMM's scope. OP might look at those too.
redwire is offline   Reply With Quote
Old 01-16-2019, 09:51 AM   #19
llonen
Yeah no I would choose Fluke over a Hioki every day for the above reasons, and regarding the 'scope function' I think it only displays up-to 200khz waveform if I read the spec correctly.
Old 01-16-2019, 05:12 PM   #20
sam_sam_sam
Yes about a Fluke but I do not want to pay that much for that type of meter yes I am a tight ass but can not help it
