Go Back   Badcaps Forums > Troubleshooting Hardware & Devices and Electronics Theory > General Electronics Technical Discussion
Old 01-06-2019, 11:22 AM   #1
nbdy
City & State: Sv.Nedelja,Bestovje
My Country: Croatia
Line Voltage: 220VAC/50Hz
I'm a: Hobbyist Tech
Default Unknown components
sorry if this is in wrong discussion ...
I had a little problem with my power supply (used the wrong cable), and burned 2 components on my SSD ...
the one is 3012 743J4 SOT25,and the other 3013 (other is burned) TSSOT 8 pin
here the pictures ...
https://www.dropbox.com/s/8mdpyd2dz4...52912.jpg?dl=0
https://www.dropbox.com/s/4s0cybehnk...62956.jpg?dl=0
can anyone say what for a part it is to order it ...
thx
nbdy is offline   Reply With Quote
Old 01-06-2019, 04:34 PM   #2
sam_sam_sam
City & State: Sunny Jacksonville FL
Line Voltage: 120 Volts 60 HZ
Default Re: Unknown components
Can not see photos
9 PC LCD Monitor
6 LCD Flat Screen TV
1 Dell Mother Board
15 Computer Power Supply
All of these had CAPs POOF
sam_sam_sam is offline   Reply With Quote
Old 01-06-2019, 08:47 PM   #3
delaware74b
delaware74b's Avatar
City & State: Delaware
Line Voltage: 480VAC 60Hz or Less
Sam - I pulled them from OP dropbox, here you go:
Stupidity should be a crime, especially for drivers. I have NO patience for them.
delaware74b is offline   Reply With Quote
Old 01-06-2019, 10:20 PM   #4
nbdy
My Country: Croatia
thx delaware74b for pics
On the second board the U14
Old 01-07-2019, 11:53 AM   #5
sam_sam_sam
[QUOTE=nbdy;872612]thx delaware74b for pics
It might be this part
http://www.aosmd.com/res/data_sheets/AOZ3013PI.pdf
It might be this
http://www.ti.com/lit/ds/symlink/tlv3011.pdf
Old 01-07-2019, 11:35 PM   #6
nbdy
My Country: Croatia
THX,
The 5 or 6 pin makes no difference for the 3012 ??
the AOZ3013 i faund late yesterday ...
