Old 01-17-2019, 07:30 PM   #61
Amraks
City & State: Tasmania
My Country: Australia
Line Voltage: 230VAC
Default Re: Sasmung la40m81bd - Recapped
Chip I flashed is IC1803 is a 24C256
No flashed firmware after the erase as the tv writes to the chip when blank chip is detected
Can get into service menu but its very hard to navigate being the picture is the way it is.
Amraks is offline   Reply With Quote
Old 01-18-2019, 08:53 AM   #62
nomoresonys
City & State: midwest
My Country: U.S.
That chip costs 1 dollar, I'd replace it with a new one, that will at least confirm or eliminate it as a suspect.
nomoresonys is offline   Reply With Quote
Old 01-18-2019, 10:15 AM   #63
Amraks
yeah I have ordered 5 of them, seems weird that I have the off/on clicking fault now after erasing that chip.
chip sectors could be bad and its writing on the corrupt chip sectors creating incorrect settings for panel and the watchdog is now kicking in as it should be.
Old 01-22-2019, 02:35 AM   #64
Amraks
Tried a new chip not fixing any fault
2 of these caps under the metal shield
44080
82
6FA
One reads higher than the other of the same value on my esr meter
.16ohms
.04ohms
Could this be my problem?
Old 01-22-2019, 07:33 AM   #65
Amraks
Also found some of these caps on the mainboard are reading funny
100
16J
Which look to be the JC series in Samwha
some are reading
1.0ohms
.90ohms
.09ohms
there is a few of these caps all over the board it seems like the lowest readings are the rarest ones
Old 01-22-2019, 03:00 PM   #66
Davi.p
Davi.p's Avatar
City & State: Milan
My Country: Italy
Line Voltage: 230Vac 50Hz
I'm a: Hobbyist Tech
Hi, i don't like the suggestions done here in this thread..
the video shows evidently a corruption in firmware data, the part on the flash chip or the data copied into the RAM, so best way to do for me is to begin with cap replacing, for the 3,3v that feeds the Flash 29AL032 are C1110,C1177, for the DDR 2,5v is the C1149, since before or after but very often fails also C1165,C1167 change also them. I don't know what it is HYB25D256 chip, seems another flash chip, anyway if the cap replacement doesn't work then a reflashing of the firmware (NOT THE EEPROM!!) is suitable but the file is unavailable.
Davi.p is offline   Reply With Quote
Old 01-23-2019, 12:48 AM   #67
Amraks
Ok I replaced them caps you have mentioned also took the liberty of replacing C2267 and C1140
this has made a bit of difference in the picture I can recognise some text in menus but it seems a little flashy still.
Old 01-23-2019, 01:11 AM   #68
Amraks
Here is a new video
I have bought up some menus also I never switched it off, it did this by itself.
https://www.youtube.com/watch?v=WgGf9TVDFj4
Old 01-23-2019, 02:38 AM   #69
Davi.p
Davi.p's Avatar
City & State: Milan
My Country: Italy
ok maybe some caps are still bad on the mainboard, or there's a problem in the video RAM, for the shutting off then on surely the job done on eeprom is not a good thing, it must be placed back the original eeprom with original content, or right to try, delete the actual eeprom maybe with the short on pins 5,6 during the mains plug connection (stay so for 10 seconds), then shut off then on.. another common fault in theese boards is the soldering if i remember on the ST CPU.. if i'm right the ST governs the DTV (terrest. digit. tv). Try to warm it up for 30 secs at high temp, at least 300 C, then try the tv, if its better then do a reflow.
Old 01-23-2019, 03:11 AM   #70
Amraks
Not sure what's going on with that could still be processing video.
Try again soon.
Old 01-23-2019, 04:14 AM   #71
Davi.p
Davi.p's Avatar
City & State: Milan
My Country: Italy
What do you mean?? Try what? I think the most probable culprit is the ST chip and its solderings, the things are strictly related, PSU and Mainb. caps generate high ripple that causes the ST chip to get too hot then solder balls detaches itself.
Old 01-23-2019, 05:11 AM   #72
Amraks
C2267 and C1140 there is a short to ground on these two caps hmmmm
Old 01-23-2019, 05:30 AM   #73
Amraks
its weird its only doing it after board has been on
Old 01-23-2019, 06:11 AM   #74
Davi.p
Davi.p's Avatar
City & State: Milan
My Country: Italy
How do you measure this? first you have to measure in volt to be sure to not damage the tester, then you can measure in ohm with caution..
Old 01-23-2019, 09:13 AM   #75
nomoresonys
My Country: U.S.
WRONG, when these eeproms are replaced they use new blank chips.
1) https://www.youtube.com/watch?v=4F2J1Dkf4Is
HIGH VOLTAGE HAZARD demonstration. Video by Electronic Doberman.
2) https://www.youtube.com/watch?v=4v8DcqCNG4A
Power supply board voltage testing by shopjimmy.
BE VERY CAREFUL WITH POWERSUPPLY, VOLTAGE ON PRIMARY/HOT SIDE CAN BE DEADLY, THE CAPACITORS CAN HOLD A VERY BIG CHARGE LONG
AFTER TV HAS BEEN UNPLUGGED.
3) Test connector from mainboard to powerboard on powerboard side with all boards hooked up, test with tv plugged in but off then hit power, report both conditions here, give pin number, pin description/name and condition both off and when you hit power on. So we can see all the voltages and what they are doing. Try to do test just as instructed, example in link 2 if needed.
Old 01-23-2019, 10:05 AM   #76
Davi.p
Davi.p's Avatar
City & State: Milan
My Country: Italy
I reorder things, i remembered bad, then the chip erasing it's been already done, but what it's been done after? 'Cause the tv usually needs an initialisazion, it's been made it ('cause before cap replacing the characters of the OSD was no readable)? So the chip has not been changed and the original content is lost.. now that characters are visible a little a service menu reset must be made, with TV initialisation after..
Old 01-23-2019, 11:01 PM   #77
Amraks
I have gave up on this tv only solution would be a mainboard.
Old 01-24-2019, 01:55 AM   #78
Davi.p
Davi.p's Avatar
City & State: Milan
My Country: Italy
ok i've learned a thing, never put much effort in a forum!...
Old 01-24-2019, 03:47 AM   #79
Dannyx
CertifiedAxhole
Dannyx's Avatar
City & State: Constanta
My Country: Romania
Line Voltage: 230VAC 50Hz
I'm a: Hardcore Geek
Your effort is much appreciated, as it can be useful to others out there
Wattevah...
Dannyx is offline   Reply With Quote
Old 01-24-2019, 04:37 AM   #80
vinceroger69
City & State: Nuneaton Warwickshire
My Country: uk
maybe search you local free adds etc or ebay for a cracked screen set if you cant find a replacement mainboard cheap enough.
vinceroger69 is offline   Reply With Quote
