Old 12-21-2018, 08:34 AM   #41
nomoresonys
City & State: midwest
My Country: U.S.
Default Re: Sasmung la40m81bd - Recapped
This one matches first 9 numbers? https://www.ebay.co.uk/itm/272695645973
nomoresonys is offline   Reply With Quote
Old 12-21-2018, 08:55 AM   #42
Dannyx
CertifiedAxhole
Dannyx's Avatar
City & State: Constanta
My Country: Romania
Line Voltage: 230VAC 50Hz
I'm a: Hardcore Geek
That's cheap...I'd say there's nothing to lose by getting it. If anything, you'll have it as a spare. This is what I used to do back at my old shop: when I wasn't sure which part was faulty, if it wasn't terribly expensive, I'd buy it and keep it as a spare if it turned out that wasn't the issue...ah the good ol' days when I was virtually running my own shop....none of this corporate sh!t where nobody cares about you and you're basically left unscrewing flat heads with philips...>_>
Wattevah...
Dannyx is offline   Reply With Quote
Old 12-21-2018, 09:08 AM   #43
nomoresonys
My Country: U.S.
Whole page to look thru, might be a match somewhere, if those 2 don't work? https://picclick.co.uk/Tcon-Board-40...987820813.html
Old 12-22-2018, 12:44 AM   #44
Amraks
City & State: Tasmania
My Country: Australia
https://www.aliexpress.com/item/free...6-7aa4934d380a
Found one cheaper and don't mind the 4 week wait.
I could only try a new tcon and go from there I guess.
Amraks is offline   Reply With Quote
Old 01-15-2019, 09:21 PM   #45
Amraks
New T-con showed up today shipping was pretty fast.
The result wasn't what we was hoping for still got the same picture error.
So problem would be on mainboard wouldn't it?
Old 01-16-2019, 03:42 AM   #46
angelos
City & State: Free State
My Country: South Africa
Line Voltage: 220V AC
Hi Amraks, i have never seen your youtube video because of it being blocked here at work but sometimes the bonding tabs cause weird issues. I hope its not that in your case otherwise you're stuck with a scrap tv.
angelos is offline   Reply With Quote
Old 01-16-2019, 04:46 AM   #47
Amraks
Pretty sure this isn't a tab bond issue.
Have been reading about ic1803 going bad after bad caps
This here is from a bulletin from Samsung about this tv
Symptoms
HTML Code:
   No Power, Keeps clicking, Clours incorrect, No DTV / ATV,  No DTV or RF signal on TV.
   SMPS capacitor failure causing No power or No DTV to above models.
   This is due to EEprom value in Factory setting change when SMPS failure (side effect
Solution
HTML Code:
 Product  :
LCD TV
Bulletin No.    : 10-LCD_TV-A003
 Model     :
LA 40/46/52 M81BDX/XSA
Bulletin D 24 Apr 2010
LA40/46 N81BDX/XSA
Buyer        SEAU
LA32/40 R81BDX/XSA
LA32/40/46 S81BDX/XSA
LA40/46/52 F81BDX/XSA
Subject   :
SMPS failure due to SamHwa Cap causing MAIN BOARD EEPROM setting change
   This is due to EEprom value in Factory setting change when SMPS failure (side effect)
[Step1]
  Replace Capacitors which bloated from SMPS (Refer Table below)  & perform data adjustment in [Step 4]
                ** If still fails to power on and keeps clicking refer steps 2, 3 & 4:
[Step2]
    Replace Eprom IC1803 (8 Pin surface Mount IC)
                ** Once power on for 1st time after Eprom replacement TV will click on / off 3 times then picture will illumina
te
[Step3]
    Access Service Mode  Press the following
                ** TV in off state then on remote press INFO  MENU  MUTE  POWER ON
[Step4]
 Perform Data Adjustment in SVC Mode (2.Option table & 8.Adjust menu, refer following pages)
Old 01-16-2019, 06:59 AM   #48
nomoresonys
My Country: U.S.
Definitely worth a try, can you find the eeprom? not sure if this eeprom needs to be pre-programed???
Old 01-16-2019, 08:48 AM   #49
nomoresonys
My Country: U.S.
One guy used this one: https://au.element14.com/microchip/a...oic/dp/1972001
Old 01-16-2019, 09:15 AM   #50
Dannyx
CertifiedAxhole
Dannyx's Avatar
My Country: Romania
Video's been removed probably since I can't access it either....
Old 01-16-2019, 10:31 AM   #51
vinceroger69
City & State: Nuneaton Warwickshire
My Country: uk
I'm a: Hobbyist Tech
I have repaired a couple of older samsungs once i have replaced all the bad caps i then replace the eeprom with a blank new one once the sets starts up usually a few attempts the tvs have been fine i guess the set somehow re writes its own eeprom data back too the new ic
vinceroger69 is offline   Reply With Quote
Old 01-16-2019, 11:08 AM   #52
Diah
City & State: SA
My Country: Germany
+1
especially when the firmware contain the eeprom bin. which any TV able to downgrade its firmware had this section and can be noticed that the TV start downgrade or upgrade its start twice
Diah is offline   Reply With Quote
Old 01-16-2019, 09:41 PM   #53
Amraks
Ignore the first video it had kids screaming in backgroup
Heres the video I took once I had it in my hands.
https://www.youtube.com/watch?v=d3zC...ature=youtu.be
Old 01-17-2019, 12:31 AM   #54
Amraks
I ended up pulling off the chip and erasing it.
now the tv is switching on and off every 2(roughly) mins still have the fuzz pattern.
Old 01-17-2019, 03:16 AM   #55
vinceroger69
My Country: uk
my guess would be a mainboard issue what mainboard is used in this set
Old 01-17-2019, 03:31 AM   #56
Amraks
Mainboard is BN41-00888B
Given that I have this new fault would mean the eeprom chips data isn't getting written.
Old 01-17-2019, 08:27 AM   #57
Amraks
well I took the chip off the board and read the chip there is data being written but still getting this new fault so would it be safe to say this chip faulty and getting corrupted.
Old 01-17-2019, 08:30 AM   #58
Dannyx
CertifiedAxhole
Dannyx's Avatar
My Country: Romania
You could try replacing it, though I believe at this point it's a main board issue and should replace that instead.
Old 01-17-2019, 09:00 AM   #59
vinceroger69
My Country: uk
looking at your photos in post one it looks like your mainboard is a BN94-01200B (on white sticker) although i cant seem too find any for sale maybe you could look on shop jimmy and see if you can use another mainboad
Old 01-17-2019, 09:20 AM   #60
Diah
City & State: SA
My Country: Germany
how about you write to us the chip No you erased ?
did you flashed firmware after erase ?
did you logged in Service menu and from there you reset the TV ?
