Old 12-12-2018, 04:54 AM   #1
Amraks
City & State: Tasmania
My Country: Australia
Line Voltage: 230VAC
Default Sasmung la40m81bd - Recapped
History:
PSU only recapped.
This TV was not turning on a few weeks ago I then recapped it as I recall I swapped all capacitors except a 163v 1uf as I didn't have this value.
A few weeks pass.
The TV now is coming back to me with with a picture fault.
https://youtu.be/sYJE7VpX4yE
Any idea what may cause this? could it be that 163v 1uf I didn't recap?
Just want this customer to have their tv back as I have their other one at the moment as well.
Amraks is offline   Reply With Quote
Old 12-12-2018, 05:24 AM   #2
Hamie
Hamie's Avatar
City & State: Scotland
My Country: UK
I'm a: Forum Junkie
Default Re: Sasmung la40m81bd - Recapped
Try heating the main board metal shield. If the picture comes back then it's probably the 2 x 1000uf caps under the tin work.
Hamie is offline   Reply With Quote
Old 12-12-2018, 05:51 AM   #3
Amraks
They where replaced though with new ones. forget which brand I used for them.
Ill check their ESR when it comes back.
Any idea what the 1uf 163v would do?
Old 12-12-2018, 05:54 AM   #4
Amraks
Oh Oops just noticed you meant the mainboard I originally recapped the PSU board.
Old 12-12-2018, 06:48 AM   #5
drussell
City & State: Calgary, AB
My Country: Canada
Line Voltage: 120/240V, 60 Hz
I'm a: Hardcore Geek
Just a quick aside... There is no such thing as a 163 volt capacitor rating. 63? Yes. 100? Sure. 150 or 200? Yup...
Even 160 and 165 are something that (while rare), do actually exist but I've never seen a 163 volt capacitor.
drussell is offline   Reply With Quote
Old 12-17-2018, 06:32 PM   #6
Amraks
its a 160v not sure how I got 163v.
I can not see how it could be a cap on the mainboard as they are smd
Old 12-17-2018, 08:25 PM   #7
nomoresonys
City & State: midwest
My Country: U.S.
Video resembles a tcon problem?
nomoresonys is offline   Reply With Quote
Old 12-17-2018, 09:59 PM   #8
Amraks
Heres a better video now I have the tv in my hands.
https://youtu.be/d3zCpfB23Sg
Old 12-17-2018, 10:05 PM   #9
budm
budm's Avatar
City & State: S.F. Bay area
Line Voltage: 120V 60Hz
What do you mean by ' how it could be a cap on the main board as they are SMD'? SMD is just a form factor, so if it is SMD lytics cap then they can still fail just like other lytics caps.
Old 12-17-2018, 10:12 PM   #10
Amraks
I thought they where rare to fail budm.
Old 12-17-2018, 10:23 PM   #11
nomoresonys
My Country: U.S.
Try heating things with a hairdryer on the mainboard and tcon, see if picture changes and maybe the one ribbon at a time tcon check.
Old 12-17-2018, 10:56 PM   #12
Amraks
I checked both sides of the tcon left and right, left side pulled was white with right side still showing this defect.
right side pulled was the same as well but opposite.
heated up around the main-board and tcon the problem doesn't go away.
Old 12-17-2018, 11:10 PM   #13
nomoresonys
My Country: U.S.
Check the capacitors on the tcon for shorts, tv unplugged, meter in diode mode.
Old 12-17-2018, 11:32 PM   #14
Amraks
checked all caps for shorts on the tcon board couldn't find any shorted
Old 12-18-2018, 12:14 AM   #15
Amraks
I replaced that cap on psu that I didn't have before problem is still there.
Old 12-18-2018, 07:59 AM   #16
nomoresonys
My Country: U.S.
Maybe test the voltage regulators on mainboard, tutorial if needed in budm's signature post #9.
Old 12-18-2018, 08:22 AM   #17
Dannyx
CertifiedAxhole
Dannyx's Avatar
City & State: Constanta
My Country: Romania
Line Voltage: 230VAC 50Hz
I believe you removed the video.
I'm just going to give my 2 cents nonetheless by saying it's probably a T-con issue since you're saying both sides of the screen display the same. Ideally, you'd have a second main board/T-con to compare how each performs.
Do some measurements on the t-con board: there should be test points labeled VCC, 1.2v, VGH, VGL, etc. Really curious to see how this telly gets fixed
Wattevah...
Dannyx is offline   Reply With Quote
Old 12-19-2018, 09:45 PM   #18
Amraks
Here is a photo of the tcon all the VCC lines seem to match their values I can't find vgh or vgl
Old 12-19-2018, 10:02 PM   #19
budm
budm's Avatar
How about AVDD, AVDD_1, VDD around the left side of the board around IC8?
You can also look up the spec sheet of that IC8 TPS65160A to see how many output Voltage sources it has.
Old 12-19-2018, 10:15 PM   #20
Amraks
Some more photos
