Go Back   Badcaps Forums > General Topics > General Capacitor Questions & Issues
Old 11-28-2018, 04:33 PM   #1
jayjr1105
jayjr1105's Avatar
City & State: Lancaster, PA
My Country: United States
Line Voltage: 120VAC 60Hz
I'm a: Hardcore Geek
Default Hitachi Mains Cap?
I just bought a new power supply and I've never seen this brand before.
I know the Primary filter cap quality isn't super important in a switching PSU but was just curious.
Ryzen 2600X
16GB Corsair Vengeance 3200MHz
MSI Mortar Arctic mATX
MSI Vega 56
Acer 32" 1440P Freesync
Rosewill Capstone 750W
Hakko FX-888D Station
FX-8802 Iron
Chinese 63/37 1.8%
jayjr1105 is offline   Reply With Quote
Old 11-28-2018, 04:49 PM   #2
mariushm
City & State: Romania
Line Voltage: 230VAC 50Hz
I'm a: Hobbyist Tech
Default Re: Hitachi Mains Cap?
Seasonic uses them a lot, and I don't see any complaints.
mariushm is offline   Reply With Quote
Old 11-28-2018, 05:01 PM   #3
PeteS in CA
PeteS in CA's Avatar
City & State: San Jose, CA
My Country: USA, Unsure of Planet
Line Voltage: 120VAC, 60Hz & 115VAC, 400Hz
I've seen Hitachi 450V caps quite a bit, including in server PSUs. They seem fine.
PeteS in CA
Where might is right
There is no right.
- Sophocles in "Antigone"
All that is gold does not glitter,
Not all those who wander are lost;
- J.R.R. Tolkien, The Fellowship of the Ring
PeteS in CA is offline   Reply With Quote
Old 11-28-2018, 08:43 PM   #4
jayjr1105
jayjr1105's Avatar
Thanks guys. Wasn't overly concerned but I've opened up a few PSU units and never saw a blue mains cap.
Old 11-28-2018, 10:07 PM   #5
budm
budm's Avatar
City & State: S.F. Bay area
Line Voltage: 120V 60Hz
http://www.hitachi-chem.co.jp/englis...itors/003.html
http://www.hitachi-chem.co.jp/englis...s/e_ridohu.pdf
http://www.hitachi-chem.co.jp/englis.../e_hu_550v.pdf
Old 11-29-2018, 08:01 AM   #6
jayjr1105
jayjr1105's Avatar
4000 Hours seems low for a "japanese" cap doesn't it?
Old 11-29-2018, 03:30 PM   #7
PeteS in CA
Different series have different life ratings. Keep in mind that the rating is for operation at max temperature, ripple current and applied voltage. If the real temperature and ripple current are lower, the expected life will be much greater.
Old 12-12-2018, 01:48 AM   #8
momaka
momaka's Avatar
City & State: VA (NoVA)
My Country: U.S.A.
Line Voltage: 120 VAC, 60 Hz
Not anymore. All these "new" Active PFC PSUs tend to stress the primary caps a lot more. So having Japanese caps in there matters.
Even more important is how the APFC circuit of the PSU is designed. I'm not sure if this is a coincidence or actual link, but in the last several APFC PSU repairs I did with blown APFC stages, it seems that the primary caps went bad because they weren't rated for a high enough voltage (typically only 400V), probably for the manufacturer to save money. What's concerning is that both Japanese and non-Japanese caps were affected.
So I would say that just about any APFC PSU with 400V-rated and/or non-Japanese primary caps is asking for trouble down the road.
As for Hitachi primary caps - they are okay. I don't recall seeing any failure with them.
Old 12-16-2018, 07:50 PM   #9
kevin!
recapping PCB.
kevin!'s Avatar
City & State: Gerona
My Country: Espaa
Line Voltage: 230VAC 49Hz, 2 Ph
They are very good capacitors, do not worry about their reliability.
Sony also uses hitachi for its PS3.
Gaming pc:
Gigabyte RTX 2070, Corsair RM750I.
Server:
HTPC:
Intel Xeon X3460, 8GB DDR3, MSI ms-7316, case hp pro mt3133, liteon 300w (recapped), nvidia gt 1030, samsung spinpoint 500GB.
kevin! is offline   Reply With Quote
Old 01-27-2019, 10:03 AM   #10
bestsystem
i never seen a failed primary capacitor, even in taiwanese brands
usually the output caps on DC 12V 5V rail fail first
bestsystem is offline   Reply With Quote
Old 01-27-2019, 10:26 AM   #11
R_J
City & State: ☻
My Country: Canada
Then you haven't repaired many units. I have seen hundreds, The latest was in a HP Brick power supply for an aio computer, the cap was a Rubicon 150f/400v And it looked ok but the top was not quite flat and measured 115f and would cause the P.S. to blow the fuse.
R_J is offline   Reply With Quote
Old 01-31-2019, 08:08 PM   #12
momaka
momaka's Avatar
My Country: U.S.A.
On old PSUs *without* APFC - YES, the primary caps rarely go bad.
But on PSUs with APFC, I've seen plenty of failed primary caps.
