Go Back   Badcaps Forums > Motherboards with Bad Capacitors > ECS - EpoX - Gigabyte
Old 10-13-2018, 06:49 AM   #1
caspian
City & State: Mazandaran
My Country: Iran
I'm a: Hobbyist Tech
Default Schematics of GA-EP41T-USB3
Dear forum members,
I need the schematics file of Gigabyte mainboard GA-EP41T-USB3.
The schematics of any other mainboard in this series (GA-EP41T) would be useful.
thanks
caspian is offline   Reply With Quote
Old 10-13-2018, 12:18 PM   #2
piernov
City & State: Valbonne, 06
My Country: France
Default Re: Schematics of GA-EP41T-USB3
http://sualaptop365.edu.vn/threads/s...-doi-41.12375/
OpenBoardview http://openboardview.org | IRC #openboardview@irc.freenode.net
piernov is offline   Reply With Quote
Old 10-13-2018, 02:23 PM   #3
caspian
My Country: Iran
thank you.
Let us consider a CPU_vcore circuit that has 3 PWM lines (or phases). What will be happen if I disable one line (by removing its components) such that the other two lines provide voltage for the CPU?
I mean: will be there any shortage of current or voltage for the CPU?
will the CPU_vcore circuit fail after a while of working?
Old 10-13-2018, 03:29 PM   #4
piernov
My Country: France
Multiple phases are meant to share the current to prevent excessive loss and overheating. You shouldn't run a buck converter with less phases than it was designed for. It'll indeed end up overheating and killing the other phases when under load (which may kill a high side MOSFET, sending 12V to the CPU and killing it as well). It could work if you use a lower powered CPU but I wouldn't recommend it anyway.
Also depending on the layout this will prevent the buck converter from working at all.
