Go Back   Badcaps Forums > Motherboards with Bad Capacitors > ECS - EpoX - Gigabyte
Old 05-11-2018, 01:20 PM   #1
airs
City & State: Seattle
My Country: United States
Default EpoX EP-MVP3G-M Super Socket 7 recap
Hi all, I'm looking to fully recap this Super Socket 7 motherboard as one of the Teyah 1000uf 6.3v caps on it has failed. Here are some pictures of the two types of caps used on the board (Teyah 1000uf 6.3v and Teyah 100uf 16v). Can you please give some suggestions on what to use as replacements? I'm located in the US and I typically order from Digikey or Mouser, but not opposed to ordering from elsewhere. Thank you!
airs is offline   Reply With Quote
Old 05-12-2018, 02:04 AM   #2
Sparkey55
City & State: OK
Default Re: EpoX EP-MVP3G-M Super Socket 7 recap
What is the Series and the diameter of the TAYEH 1000uf caps?
If they are 8mm in diameter these could work...
http://www.badcaps.net/store/product...products_id=46
Most likely overkill for a socket 7 board.
I can not find a data sheet for TAYEH but others say TAYEH are close to TEAPO in specs.
Sparkey55 is offline   Reply With Quote
Old 05-14-2018, 09:39 AM   #3
airs
Thank you for the reply. The diameter is 8mm on the 6.3v 1000uf caps. I’m not sure what series they are though - C925 is printed on them - is that the series?
The diameter for the 16v 100uf caps is 5mm. Any idea what I should use to replace those?
Old 05-14-2018, 01:13 PM   #4
Sparkey55
City & State: OK
Originally Posted by airs View Post
Thank you for the reply. The diameter is 8mm on the 6.3v 1000uf caps. Iím not sure what series they are though - C925 is printed on them - is that the series?
http://www.badcaps.net/store/product...roducts_id=112
Old 05-14-2018, 03:38 PM   #5
airs
Thanks Sparkey! So its not a problem in this case to increase the capacitance from 100uf to 220uf?
Badcaps.net Technical Forums © 2003 - 2019
