Badcaps.net Forum
Go Back   Badcaps Forums > General Topics > Custom Tweaks, Modifications, and Revisions
Thread Tools Display Modes
Old 02-02-2018, 11:44 AM   #1
PopcornMobo
PopcornMobo's Avatar
City & State: Lithuania
My Country: Lithuania
Line Voltage: 220-240 VAC @ 50 Hz
I'm a: Knowledge Seeker
Default Water cooling a laptop, have you seen it done?
I've found only two examples of people water cooling their laptops but they were pretty sketchy.
I'm actually in the process of water cooling my laptop. I'm doing it not because the laptop runs hot but mainly because i like overkill. The laptop only gets up to 75C full load but i want even lower temps, which is why i decided to make a custom water loop for this laptop.
I'm very curious whether or not there are more examples out there of people DIY water cooling their laptops, maybe some that i've missed (i like comparing my projects to others)
Anyways, i'll attach a pic of my custom water block and if you wish to see more you can go to my blog at brimmingideas.blogspot.com .
PopcornMobo is offline   Reply With Quote
Old 02-02-2018, 12:48 PM   #2
eccerr0r
Solder Sloth
eccerr0r's Avatar
City & State: CO
My Country: USA
Line Voltage: 120VAC 60Hz
I'm a: Hobbyist Tech
Default Re: Water cooling a laptop, have you seen it done?
I think it's kind of ridiculous of sorts - having water cooling sort of defeats the purpose of a machine meant for portability...
eccerr0r is online now   Reply With Quote
Old 02-02-2018, 02:06 PM   #3
stj
stj's Avatar
City & State: Europe
My Country: some shithole run by Israeli agents
I'm a: Professional Tech
water does not cool, it moves the heat to a different location where you fit a radiator and fan. (and a pump)
laptops already have that with liquid filled heat-pipes.
stj is offline   Reply With Quote
Old 02-02-2018, 03:27 PM   #4
eccerr0r
Solder Sloth
eccerr0r's Avatar
City & State: CO
My Country: USA
I do wonder about that too, at least the liquid filled heat pipes. Solid ones I get (though the thermal resistance would be quite high, it's still tons better than air), but wouldn't the liquid ones depend on the orientation of the laptop for effectiveness? That would mean it would need to be on stable ground (i.e. desktop machine or server?) to be useful.
Old 02-02-2018, 04:05 PM   #5
PopcornMobo
Is water cooling laptops taboo or something? The laptop i'm water cooling i found at the dump and it has no battery so i'm not concerned about the portability of it. For now i have decided to use the laptop as a platform for upgrades and experiments.
Old 02-02-2018, 04:22 PM   #6
stj
stj's Avatar
a fan upgrade would be a better start.
Old 02-02-2018, 04:52 PM   #7
PopcornMobo
Quote:
The cooling in that laptop is as good as can be but of course i want to add water cooling just for the kicks.
Old 02-02-2018, 09:13 PM   #8
eccerr0r
Solder Sloth
eccerr0r's Avatar
City & State: CO
My Country: USA
A laptop can no longer be called a "laptop" if you have water cooling on it...
Old 02-03-2018, 12:57 AM   #9
fester
City & State: Kopcany
My Country: Slovakia
Line Voltage: 230V 50Hz
This is cool idea,i use laptop also as not-portable workstation.After processor upgrade i get little more heat and i upgraded it like you see on the photos.Water cooling? Why not!! I like this idea
fester is offline   Reply With Quote
Old 02-06-2018, 03:25 PM   #10
PopcornMobo
Well, i did some quick flow tests and according to my calculations my CPU temp should be less than 30C on water, that's full load on both CPU and GPU, assuming 60W combined heat output. I might have to add some cooling to the VRM as well while i'm at it. I get about 500ml through the block in about 24 seconds. That gives me 0.048 C/W, and for antifreeze i just guessed a ballpark figure of 0.1 C/W.
Old 02-10-2018, 07:48 AM   #11
desert-rat
City & State: Avondale AZ
My Country: USA
Fester 6 more posts and you can join us in the vip room .
As the water is only a heat transfer method ,I might use some thing like R134 A . sealed in a coper tube and a remote fan . It does add weight and complexity to the lap top . On a side note when the air cooled v.w. was common . One race was for water cooled cars only . A guy made a set of v.w. heads with a water jacket just to be able to run in that race .
https://en.wikipedia.org/wiki/1,1,1,2-Tetrafluoroethane
p.s. when I think of water cooling , I think of a swamp cooler or cooling towers .
https://en.wikipedia.org/wiki/Evaporative_cooler
https://en.wikipedia.org/wiki/Cooling_tower
desert-rat is offline   Reply With Quote
Old 02-11-2018, 04:30 PM   #12
eccerr0r
Solder Sloth
eccerr0r's Avatar
City & State: CO
My Country: USA
Getting a flexible tube that can stand the heat and pressure of freshly compressed R134A really means that laptop is no longer a laptop :o However most likely the only way to get below ambient is to use phase change or Peltier...
Old 02-11-2018, 04:37 PM   #13
petehall347
City & State: worcester
My Country: United Kingdom
could run some cool led lights from peltier module
petehall347 is online now   Reply With Quote
Old 02-13-2018, 03:11 AM   #14
PopcornMobo
not sure why we're talking about sub-zero cooling, all i want is to water cool my laptop. As of now i'm busy making a sensored three phase BLDC water pump, i already have a prototype running with a homemade driver made of discrete components. The pump i used for my tests was just a little brushed motor that was made into a water pump and that is not great since the impeller is shaft-driven and a seal has to be maintained to keep the water from leaking.
Old 02-14-2018, 02:56 PM   #15
desert-rat
My Country: USA
I would think a wind shield wiper cleaner fluid pump would work . You can get the fans that set under a lap top .
Old 02-15-2018, 01:40 PM   #16
PopcornMobo
Quote:
That's actually a good idea, i had a few of those somewhere in the garage. One problem with them is that they're noisy and what i want is a quiet setup. The three phase BLDC pump should be easy enough to make and will be pretty much silent because of the angle that i'll be switching the phases.
Old 02-18-2018, 10:02 AM   #17
desert-rat
My Country: USA
There is some thing known as a thermo. electric cell . You hook power to it , one side gets hot the other side gets cold . There used mostly for small fridges . One could use one with heat sinks on both sides . The hot side vented away and the cold side vented in to the lap top .
Old 02-21-2018, 07:23 AM   #18
Th3_uN1Qu3
Believe in
City & State: Bucharest
My Country: Romania
Line Voltage: 230VAC 50Hz
The problem with TECs is that they are incredibly inefficient.
__________________
Quote:
Originally Posted by PeteS in CA View Post
A working TV? How boring!
Th3_uN1Qu3 is offline   Reply With Quote
Old 02-26-2018, 11:01 PM   #19
momaka
momaka's Avatar
City & State: VA (NoVA)
My Country: U.S.A.
Line Voltage: 120 VAC, 60 Hz
Never seen it, but thought about it once (not to do on my own laptop, but just in general).
The way I would do it: make a custom block and somehow attach it to the existing laptop heatsinks so that the laptop can be used with *and* without the water cooling. Then run short pipes from the water block out of the laptop and maybe let them hang in the back. Now here is the cool part, pun intended : get a bucket of cold water, put a pump in it with long flexible hoses, and attach to the custom water block in your laptop. Run the pump with a power adapter and leave it in the bucket, of course.
After few hours of browsing/gaming/computer usage when you go to the bathroom to take a leak (or to the kitchen to grab a snack), take the bucket with you and dump the warm water. If you went to the bathroom, you won't even need to flush your toilet tank! - Just use the water from the bucket. Then put fresh cold water, and you're ready to go back to your computer session.
Need to take the laptop with you? Disconnect water hoses and back you go to air cooling.
Well, I'm sure all of that I typed above is easier said than done. But if I were to do it, that's how I'd attempt it. Otherwise, you might as well take the laptop's motherboard out and put it into a custom enclosure/case and do whatever the heck you want with it (Pizza box or briefcase computer anyone? Oh wait, we had a thread here on that some eons ago ).
Have fun!
Old 02-27-2018, 01:23 AM   #20
ChaosLegionnaire
HC Overclocker
City & State: Singapore
My Country: Singapore
Line Voltage: 240VAC 50Hz
for me, if it was during winter, i'd soak my feet in the bucket of water. that would keep me warm whilst the cold me would cool the hot water down. gotta make good use of every joule of energy there is and not let any go to waste.
remember the physics law and the good physicist's code: energy cannot be created or destroyed. it can only be transferred from one state to another. so time to live physics!
i also saw a listing of a shoebox pc being sold in a local forum here in singapore. i'll post the link n pics if i can ever find it again lol!
ChaosLegionnaire is offline   Reply With Quote
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Badcaps.net Technical Forums 2003 - 2019
Powered by vBulletin ®
Copyright ©2000 - 2019, Jelsoft Enterprises Ltd.
