#1 |
City & State: Munchen
My Country: Germany
![]() Hello everyone.
I am new here, and i am new in the industry(i started to work in a local repair shop a few weeks ago). I have a laptop Lenovo 500-15isk with the following symptoms: starts with the battery, do not charge|does not see DC adapter. without battery turns on for a second, then shuts down. Amp consumption hits 0.5A then goes back to fluctuation 0.1..0.2 with a tiny noise near the charging circuit. Could not find schematics diagram and i also do not have enough experience to find all control voltages without it. I would appreciate any clues and ideas. |
#2 |
My Country: Germany
![]() So I fixed this board today. after checking chip voltages i found that VCC drops from 19v to 3.1v on one tiny resistor which looked more like a fuse. i googled a little bit and found the same exact problem with the same exact symptoms on some Russian forum. I decided to short this resistor and it really worked. It was a 10om resistor, and i replaced it with a tiny copper wire.
even though i could not find this board schematics anywhere, chip datasheet really helped me to troubleshoot this issue. |
#3 |
City & State: Puerto Rico
My Country: US
Line Voltage: 120VAC 60Hz
![]() Useful information Thank You for sharing.
A Picture of subject is always Welcome Things saved from the e-landfill: Vizio VA26LHDTV10T 26" - Bad EEPROM Cap Asus PTGD1-LA Full Recap - Cha1 DDR socket damage MSI PM8M3-V Unstable CPU Recap CPU VRM circuit ViewSonic VA712B - still working on it Kindle Fire USB Connector MSI G31M-F Full Recap - Record Breaker done in 3Hrs. MSI P67A-G43 BIOS chip Reprogram - Tested and Happy The list will go on thanks to the people of this forum and many hours of reading. ![]() |
Thread Tools | |
Display Modes | |
