Old 01-05-2019, 01:07 AM   #21
jackyl
City & State: Chantilly, VA
My Country: US
Default Re: Auria EQ276W - Looking for Replacement LED Driver
Originally Posted by momaka View Post
No need to replace the glue. It was put there simply to prevent the caps from moving while being soldered at the factory and also helps protect them during shipping of the monitor. (A hard drop can make them pull out of their leads).
That said, also scrape away all the black sooth that has burned from that board. Then wipe with IPA. You might have to do this several times until you see a somewhat less charred PCB underneath. The black sooth can be conductive, so that's why it needs to be cleaned.
You may also have a burned MOSFET and diode. Possibly a controller too. Not an easy fix if you don't have much tools and you've never done any soldering before. But not that hard if you have soldered at least a few times before.
I was talking about removing the glue from the replacement board I'm getting. Someone in a previous post said the failure wasn't caused by a blown capacitor, but had something to do with the glue that was holding it to the board. You can see from the pic I put in my previous post that the current board is pretty much hosed... I tried cleaning it but the damage was actually into the board. I have no problem soldering, but I don't really have the tools to figure out what components are damaged, other than obvious visual failure. So I guess the real question is when I get the replacement board, I should or should not remove the glue?
jackyl is offline   Reply With Quote
Old 01-05-2019, 03:24 AM   #22
momaka
momaka's Avatar
City & State: VA (NoVA)
My Country: U.S.A.
Line Voltage: 120 VAC, 60 Hz
I'm a: Hobbyist Tech
Oh, I see, it's the tan/brown glue under the coils/inductors.
Yes, definitely remove all of that glue from the replacement board. Looks pretty similar (if not the same thing) to the glue that goes conductive (and corrosive) over time and just shorts things out.
Best way to do it... use brute force on the glue - sharp knife, pliers, cutters, etc. Just be careful not to damage the board or components while doing that.
Old 01-08-2019, 08:15 PM   #23
jackyl
My Country: US
I got the board I ordered today and the monitor is working again. I was going to scrape off the glue, but I was wondering if the board I got might be an update from the original. The glue on this board is white, not brown.... is there a difference, or should I remove this glue as well?
Old 01-09-2019, 12:21 PM   #24
momaka
momaka's Avatar
My Country: U.S.A.
What kind of white glue?
If it's soft(er) and feels like rubber or silicone, it's OK.
But if it's hard and off-white / tan and with rough texture, it might be more of the conductive glue that hasn't baked yet.
Most likely it's the former, but worth checking. It would be nice to know the manufacturer has figured out this problem with the glue and corrected it. (Though, it really is silly that they haven't figured it out earlier. The problem with the tan/brown conductive glue has been known for decades! Why some manufacturers insist on using it is beyond my comprehension. Most likely cost-related if I had to guess. Or they know and it's just part of the planned obsolescence scheme. Who knows!)
Old 01-09-2019, 02:30 PM   #25
jackyl
My Country: US
Thanks for the info! I just tested it with a pick tool, and it appears this substance is MUCH softer than the glue on the original board. I can pretty easily push into the white substance, but the other glue is like hard plastic.
Old 01-09-2019, 03:36 PM   #26
momaka
momaka's Avatar
My Country: U.S.A.
Good. That's probably white silicone / RTV. It's okay for electronics. As far as I know, it doesn't cause corrosion and isn't conductive. So you can leave it.
Old 01-10-2019, 08:03 PM   #27
jackyl
My Country: US
Just wanted to thank everyone for their posts; you helped me get my monitor back in use after over a year!
Old 01-12-2019, 05:59 PM   #28
momaka
momaka's Avatar
My Country: U.S.A.
You're welcome! Glad you reported your success, too - should come helpful for anyone that has one of these and wants to fix it.
Old 02-06-2019, 08:28 PM   #29
Terrh
City & State: Windsor, Ontario
My Country: Canada
Can you post a link to the board you bought? Mine is still dead a year later. I am so glad that you were able to find a board!
Terrh is offline   Reply With Quote
