Go Back   Badcaps Forums > Troubleshooting Hardware & Devices and Electronics Theory > Equipment Usage, Soldering, Techniques, and Reviews
Old 12-12-2016, 10:45 AM   #1
RethoricalCheese
City & State: Tartu
My Country: Estonia
Default Motherboard POST card
Are they any good on newer desktop and laptop motherboards?
Which ones are good?
My main objective is to see whether it's a faulty BIOS or something else is faulty.
RethoricalCheese is online now   Reply With Quote
Old 12-20-2018, 09:30 AM   #2
SoporteHR
City & State: Barquisimeto / Lara
My Country: Venezuela
Line Voltage: 110VAC 60Hz.
Default Re: Motherboard POST card
Hello, receive a warm greeting
A query, in your experience, it is worth buying those cards for the diagnosis of PCI-e ports.
I'm starting to repair motherboards, I still have a lot to learn and get tools for my workshop.
That's why I consult about the usefulness of these cards.
It happens to me that I have motherboards that turn on and off after a while and that disconcerts me.
Thank you and I remain attentive to your comments.
SoporteHR is offline   Reply With Quote
Old 12-20-2018, 11:43 AM   #3
stj
stj's Avatar
City & State: Europe
i dont think they will help, for 2 reasons.
1: the numbers are sent from the bios - no bios, no numbers.
2: most problems either prevent the board starting or cause randon shit when it's running.
Old 12-22-2018, 08:28 PM   #4
llonen
City & State: united kingdom
My Country: hampshire
Line Voltage: 240 VAC 50Hz / 110 VAC 50 Hz and 415 VAC 50Hz
I have a throughput of motherboards, mostly I work on Macbook products and thus don't have a lot of use for Motherboard post cards, that said a brief look through Ebay shows a substantial number of them and with prices starting at under 5.00 so why not. Your probably better off with a few pieces of test equipment and boardview packages, I have a vast libray of boardview stuff that I would not be without for testing and diagnosis.
llonen is offline   Reply With Quote
Old 12-26-2018, 08:11 AM   #5
SoporteHR
Hi. sjt and llonen
Thank you for your response, I see that it is better to invest in something else.
Old 12-29-2018, 11:55 PM   #6
momaka
momaka's Avatar
City & State: VA (NoVA)
My Country: U.S.A.
Line Voltage: 120 VAC, 60 Hz
I'm a: Hobbyist Tech
In my experience, POST cards only appear to be -somewhat- useful for -older- desktop motherboards. On newer motherboards, I don't always get a POST code. And on laptops... well the type of POST card I used on laptops required a parallel port and those have been gone from laptops for a long time now. So for laptops... no, not useful.
In short, POST cards have a very limited use on my bench.
Old 12-30-2018, 08:58 AM   #7
stj
stj's Avatar
laptops now post through the modem/wifi socket or an extra connector - seen it on the schematics
Old 01-02-2019, 10:55 AM   #8
SoporteHR
I know that now there are POST cards that connect to the mini PCI slot where the WIFI card goes. I will review the schemes in more detail.
Thanks for your coments
Old 01-06-2019, 10:13 AM   #9
llonen
Well given the current price of a range of POST cards and the plethora of them about, I wold say try one if you think your going to use it. Its not like its going to be a significant investment, that said I have never had a board or Macbook in where one of these would be of the slightest use.
Old 01-06-2019, 11:32 AM   #10
SoporteHR
Thanks, that I wanted to know.
Here in Venezuela it is difficult to get currencies $ and locally they have a prohibitive price.
Better to invest in something else.
Old 01-16-2019, 01:47 PM   #11
RethoricalCheese
City & State: Tartu
My Country: Estonia
Well, a lot of talk but I don't see any recommendations about the cards. Which cards has anyone tried? Something that works using miniPCIe, m.2 or even DDR3/DDR4 slot (apparently there is a DDR2/DDR3 post card out there but I have no idea if it even works as promised).
Only need it for laptops.
Old 01-19-2019, 12:23 PM   #12
ktmmotocross
Boardkiller
ktmmotocross's Avatar
City & State: slovakia
My Country: slovakia
Line Voltage: 230VAC 50Hz
have abou 5 types of post cards for laptop but nearly non of them will help. works only on older laptops /ddr2/ and codes they give will not help
ktmmotocross is offline   Reply With Quote
Old 01-20-2019, 01:03 PM   #13
Conste
City & State: Stuttgart
My Country: Germany
Line Voltage: 230V AC 50 Hz
I purchased a mini PCI-E card and it doesn't work in any laptop I have here to repair. Some DELL Inspirion N7110 didn't even boot with the card inserted.
Some Asus just shows 0 all the time
Conste is offline   Reply With Quote
