Old 08-19-2013, 03:56 PM   #1
oden08
Default Dell 3007wfp faulty power supply?
Hello, I recently was given a Dell 3007wfp monitor that doesn't power on. No amber light, no nothing. Did some research and found some very good information for the Dell 3008wfp here - (http://www.badcaps.net/forum/showthread.php?t=14195) and thought it would translate to my monitor. Got it apart and there isn't a corresponding D22 that I can see and no bulging caps.
I was wondering if anyone could point me in the correct direction as anything would be very appreciated.
Attaching a pic of the power supply.
oden08 is offline   Reply With Quote
Old 08-20-2013, 01:23 PM   #2
oden08
Default Re: Dell 3007wfp faulty power supply?
Anyone have any thoughts? I have noticed some around the WWW that have posted about fixing the 3007 by replacing D22 but can't find D22 - possibly D221?
What strategy do you all use to test the components of busted PS's?
Old 08-21-2013, 04:27 AM   #3
oden08
Anyone?
Old 08-24-2013, 03:56 AM   #4
Gingerbeer
City & State: IoW
My Country: UK
There is a fuse on the power board - Mine was buried under a huge glob of hot glue, so look around. Run a continuity test on it, and replace it if needs be. That's all that was wrong with mine, and it's been fine for the last 18 months.
eidt - I can see it right next to your mains input, in that pic.
Gingerbeer is offline   Reply With Quote
Old 09-01-2013, 11:12 AM   #5
oden08
Thanks Gingerbeer, yeah checked the fuse first and it seems ok, tried to check the diodes in circuit but as I understand it you can't check diodes in circuit. About out of ideas.
Old 09-22-2013, 08:28 AM   #6
slabklab
City & State: sa
My Country: Australia
I have the same problem pretty much and tried the same approach but got nowhere. The monitor Has been sitting on my bench for a few months now.
Have you made any further progress?
slabklab is offline   Reply With Quote
Old 09-23-2013, 06:27 AM   #7
bigjohn22
City & State: Sydney NSW
Your picture is very blurry and it doesn't help.
bigjohn22 is offline   Reply With Quote
Old 10-15-2013, 05:59 AM   #8
vangnet
City & State: Hollands Kroon
My Country: Nederland
Hello, I'm new here, but i have the same problem.
Looking on the board i have found: the 17N80C3 (power transistor) was burned out, the capacitor 101 1Kv was burned. Now i try to buy the transistor.
Cost 6,00.
i am searching for more problems, but biggest problem is time.
vangnet is offline   Reply With Quote
Old 10-15-2013, 09:03 AM   #9
budm
budm's Avatar
City & State: S.F. Bay area
Line Voltage: 120V 60Hz
Better pictures of both sides of the board will help.
Old 12-21-2018, 10:07 AM   #10
plumpie
My 3007WFP turns off after a few hours, and then when I turn it on again, the time between turning off is in minutes.
This is a different failure mode then what most people here have, so can it still be d22?
To check the caps, I bought a mesr-100 esr meter, it seems to work well on some old caps I have lying around, and the ESR of the caps seems to be good (<0.1 ohms on all, except for c17 which isn't electrolytic but I can't seem to measure the ESR on this one). So it doesn't seem to be the caps.
Should I still buy a new diode for d22? What can can cause the monitor turning off after it's warmed up?
plumpie is offline   Reply With Quote
