Badcaps.net Forum
Go Back   Badcaps Forums > Troubleshooting Hardware & Devices and Electronics Theory > Troubleshooting Power Supplies and Power Supply Design
Thread Tools Display Modes
Old 01-15-2019, 06:36 AM   #1
zhang
City & State: batam
My Country: indonesia
I'm a: Knowledge Seeker
Default Dimension Schematic Reading
Is there anybody who can show me the way of knowing the dimension of the photo attached?
I tried to figure it out, but in vain.
zhang is offline   Reply With Quote
Old 01-23-2019, 10:50 PM   #2
Kdog
Materials Tech
City & State: Redmond, WA
My Country: USA
I'm a: Hardcore Geek
Default Re: Dimension Schematic Reading
Late - as usual - If 124 is wire to wire, and container is 128, then each wire = 2, right am I missing something?
Kdog is offline   Reply With Quote
Old 01-24-2019, 12:34 AM   #3
budm
budm's Avatar
City & State: S.F. Bay area
My Country: USA
Line Voltage: 120V 60Hz
Lead spacing (BSC = Basic Spacing between Centers) e = 0.40 mm.
Leg width b = 0.16 mm.
So dimension from end pin center to end pin center is 0.40 x 31 = 12.40 mm.
Body dim. D1 = 14.00 mm.
Body thickness A2 is 1.4 mm
https://reservice.pro/upload/Datasheets/kb9012qf.pdf
https://d3uzseaevmutz1.cloudfront.ne...kageGuide5.pdf
see page 27 for 128 pin 14 x 14 mm.
BSC: https://www.maximintegrated.com/en/g...m/BSC/gpk/1119
__________________
budm is offline   Reply With Quote
Old 01-24-2019, 07:29 PM   #4
sam_sam_sam
City & State: Sunny Jacksonville FL
My Country: USA
Line Voltage: 120 Volts 60 HZ
Quote:
Originally Posted by budm View Post
Thanks for sharing this
__________________
9 PC LCD Monitor
6 LCD Flat Screen TV
10 Desk Top Power Supply
1 Dell Mother Board
15 Computer Power Supply
1 Over Head Crane Current Sensing Board
All of these had CAPs POOF
sam_sam_sam is offline   Reply With Quote
Old 01-26-2019, 05:29 AM   #5
zhang
City & State: batam
Quote:
I don't actually understand each wire = 2
Old 01-26-2019, 05:37 AM   #6
zhang
City & State: batam
Smile Re: Dimension Schematic Reading
Thank you very much
It help me alot
Old 01-26-2019, 09:41 PM   #7
budm
budm's Avatar
My Country: USA
I am glad it helps. Always learning something everyday.
I use to do PCB component library and validation so I have make sure I get the correct dimensions otherwise we will be making lots of bad PCB and I will be in big trouble.
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Badcaps.net Technical Forums 2003 - 2019
Powered by vBulletin ®
Copyright ©2000 - 2019, Jelsoft Enterprises Ltd.
