Badcaps.net Forum
Go Back   Badcaps Forums > Troubleshooting Hardware & Devices and Electronics Theory > Troubleshooting TVs and Video Sources
Thread Tools Display Modes
Old 01-21-2019, 08:02 PM   #1
MvZiC MaN
City & State: Florida
My Country: United States
I'm a: Knowledge Seeker
Default Samsung UN40J5200AFXZA Color Issues
Picked up this TV at the curb. Everything seems to work flawlessly except a sleight color issue. i was hoping to be able to repair it and replace my current one.
Its hard to see in the pictures.
Note the sleight green hue around the flame on the top right of the 2nd picture.
https://www.badcaps.net/forum/attach...7&d=1548122359
https://www.badcaps.net/forum/attach...8&d=1548122359
additional photos are of the Power and Motherboards
https://www.badcaps.net/forum/attach...1&d=1548122359
MvZiC MaN is offline   Reply With Quote
Old 01-23-2019, 01:27 PM   #2
cheeky2
City & State: london uk
My Country: uk
Default Re: Samsung UN40J5200AFXZA Color Issues
I had an identical issue actually worse than yours on a Samsung UE48J5200AK model.
After purchasing a cheap tcon board for it it didn't resolve issue. So replaced main board and resolved issue. Then found two flash ics on the boards. I cloned the new board flash ics and programmed them onto the old board. The old main board was then repaired and now listed back on ebay.
So in conclusion you have firmware corruption on the eeprom ic 24c256 and flash ic 25q40.
cheeky2 is offline   Reply With Quote
Old 01-23-2019, 08:51 PM   #3
MvZiC MaN
I dont have the ability to flash an eeproom atm. But it looks like the Mainboard for this tv isnt very pricy so ill start with replacing that and hope that fixes it. Thanks for the info!
Old 01-23-2019, 11:51 PM   #4
nomoresonys
City & State: midwest
My Country: U.S.
Did you try a firmware update/reapply?
nomoresonys is offline   Reply With Quote
Old 01-24-2019, 01:53 PM   #5
MvZiC MaN
Question Re: Samsung UN40J5200AFXZA Color Issues
Ya know, Honestly I didnt even really think about that. I will give that a try when i get off work tonight. Is that something i can do through te tv? or do i need to use my PC and Update via USB?
Old 01-24-2019, 09:57 PM   #6
nomoresonys
My Country: U.S.
Came up with this, not exactly sure if it's right or not tho: https://www.samsung.com/latin_en/sup...N40J5200AFXZA/
Old 01-27-2019, 10:57 PM   #7
MvZiC MaN
Heres a couple better pics. Note the ring around the "HOME" icon.
https://www.badcaps.net/forum/attach...7&d=1548651350
https://www.badcaps.net/forum/attach...8&d=1548651350
Still doing the same after running the Firmware update. So im assuming im gonna have to replace the MoBo?
Old 01-28-2019, 12:31 AM   #8
jjanssen7
City & State: Chilliwack, BC
My Country: Canada
I have the same model tv with a similar problem and have tried a few main boards which all display the same. On my tv the tcon is integrated with the panel. I believe the problem is on the tcon. The UE48J5200AK mentioned above has a separate tcon so his experience may be different than ours.
jjanssen7 is offline   Reply With Quote
Old 01-28-2019, 07:04 AM   #9
nomoresonys
My Country: U.S.
This tcon may be compatible, I would call shopjimmy and see if they can verify compatibility or not. https://www.shopjimmy.com/samsung-bn...-con-board.htm
Old 01-28-2019, 07:12 AM   #10
nomoresonys
My Country: U.S.
This may be a match. https://www.ebay.com/itm/SAMSUNG-40-...gAAOSwM4xXZh~F
Check the sticker on your tcon for BN95-01940B
Old 01-28-2019, 07:32 AM   #11
nomoresonys
My Country: U.S.
Those are for models without integrated tcons of course.
Old 01-28-2019, 01:06 PM   #12
MvZiC MaN
Quote:
Here is the back of my TV. I think mine has an integrated Tcon.
https://www.badcaps.net/forum/attach...5&d=1548702341
Old 01-28-2019, 10:10 PM   #13
nomoresonys
My Country: U.S.
Think so, thinking those I listed are probably for older tvs.
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Badcaps.net Technical Forums 2003 - 2019
Powered by vBulletin ®
Copyright ©2000 - 2019, Jelsoft Enterprises Ltd.
