Badcaps.net Forum
Go Back   Badcaps Forums > Troubleshooting Hardware & Devices and Electronics Theory > Troubleshooting TVs and Video Sources
Thread Tools Display Modes
Old 01-23-2019, 10:11 AM   #21
cliff_hootarski
City & State: OKC, OK
My Country: USA
Line Voltage: 120vAC 60Hz
I'm a: Knowledge Seeker
Default Re: Samsung LN40A550P3F 40" HDTV, slow to turn on
Can you verify that the piggy back cap negative ( - ) end is on the left side of the original cap. The stripe on the original cap is the positive ( + ) end.
cliff_hootarski is offline   Reply With Quote
Old 01-23-2019, 02:35 PM   #22
aaronwt6
City & State: Savannah, Georgia
My Country: US
Line Voltage: 120VAC 60Hz
I'm a: Hobbyist Tech
Personally, I've never had any luck with changing that chip. Either the capacitor does the trick or nothing works. I do typically change C131 on the front of the board as well (same cap rating as C102).
Quote:
Originally Posted by samsonite View Post
This video at 5:00 explains that both c102 and a nearby 8-pin IC chip should be replaced:
https://www.youtube.com/watch?v=oC4f2Ik8rCI
They also used a heat gun and tweezers to remove that stubborn SMD, btw. I don't have a heat gun, so I would
need some kind of heat clamp to remove the SMD in one go.
My IC chip says:
MP2363DN
83833419
MPS818
My Main Board:
BN41-00975B (2008.01.13)
MODEL: PEARL
This link doesn't describe the IC chip they sell:
https://www.shopjimmy.com/samsung-bn...a530p1fxza.htm
Is this the chip?
https://www.digikey.com/product-deta...366-ND/5299123
I could try replacing that as a last resort. Does that sound reasonable?
aaronwt6 is offline   Reply With Quote
Old 01-23-2019, 02:40 PM   #23
nomoresonys
City & State: midwest
My Country: U.S.
Yes, I remember them changing both C131 and C102 also.
nomoresonys is offline   Reply With Quote
Old 01-23-2019, 03:23 PM   #24
samsonite
City & State: Detroit, MI
My Country: USA
I may try to re-solder C102 again. I think I need a cheap heat gun, because it isn't coming off for me.
And C131 is on the opposite side of main board near a power connector. It looks crowded, so I will have a difficult time with it without a heat gun.
samsonite is offline   Reply With Quote
Old 01-23-2019, 08:02 PM   #25
tvtimmy
tvtimmy's Avatar
City & State: milwaukee,wi
My Country: usa
Line Voltage: 120VAC/60HZ
Just add solder to both sides of the cap and you could use both irons to heat both sides at once and remove it.
tvtimmy is offline   Reply With Quote
Old 01-24-2019, 10:24 AM   #26
dick_barton
dick_barton's Avatar
City & State: Cardiff
My Country: Wales
Line Voltage: 230V AC, 50Hz
What DC voltage do you have across the capacitor you soldered in?
__________________
dick_barton is offline   Reply With Quote
Old 01-24-2019, 11:25 PM   #27
samsonite
My Country: USA
Quote:
That sounds like a good idea. I was trying to wick away solder instead of adding more. But my luck, the solder will ball up and stick to the iron instead.
As for the voltage, sorry, I don't know. How do shops test these boards when they only have the board and no TV?
Old 01-25-2019, 07:27 AM   #28
nomoresonys
My Country: U.S.
Solder iron prep. https://www.youtube.com/watch?v=7PWmMxjXwYE
Old 01-25-2019, 04:07 PM   #29
budm
budm's Avatar
City & State: S.F. Bay area
My Country: USA
Line Voltage: 120V 60Hz
https://www.badcaps.net/forum/attach...2&d=1548278425
What is that silver color blob between the two legs on that added on cap?
__________________
budm is offline   Reply With Quote
Old 01-25-2019, 06:56 PM   #30
samsonite
My Country: USA
Quote:
Yes, I realize I would get a better connection if the capacitor legs actually touched the pads instead of being blobbed on, but that's the best I can do with the tools I have. I don't have the hottest iron or the smallest diameter solder core right now. But, I think I'm going to put this project on hold for another week until I get some better stuff. Thanks.
Old 01-25-2019, 07:17 PM   #31
tvtimmy
tvtimmy's Avatar
My Country: usa
Take a pic of the capacitor from the legs. There looks like a "blob" between the legs what brand is that capacitor?
Old 01-25-2019, 08:31 PM   #32
budm
budm's Avatar
My Country: USA
I am talking about the silver blob between the two legs (where the legs come out of the body of the cap) of that Blue shown in your picture.
Old 01-29-2019, 06:09 PM   #33
samsonite
My Country: USA
It must be the lighting, because it's really some kind of black plastic plug. Specs call it "sealing rubber". The cap doesn't look ruptured. That's the way I received it.
I was looking at these.
P11196-ND (FC)
47F 16V Aluminum Electrolytic Capacitors Radial, Can 1000 Hrs @ 105C
https://www.digikey.com/product-deta...1196-ND/356100
P14478-ND (GA)
47F 10V Aluminum Electrolytic Capacitors Radial, Can 1000 Hrs @ 105C
https://www.digikey.com/product-deta...478-ND/2504567
P12923-ND (FM)
47F 25V Aluminum Electrolytic Capacitors Radial, Can 2000 Hrs @ 105C
https://www.digikey.com/product-deta...2923-ND/762833
P10267-ND (FC)
47F 25V Aluminum Electrolytic Capacitors Radial, Can 1000 Hrs @ 105C
https://www.digikey.com/product-deta...0267-ND/266276
Old 01-30-2019, 03:46 AM   #34
Davi.p
Davi.p's Avatar
City & State: Milan
My Country: Italy
Line Voltage: 230Vac 50Hz
The cap is a Panasonic, red M stays for Matsushita.. anyway the not removing the old cap is not a good thing, tantalum caps last longer than electrolytic ones for a matter of capacity but them can go short circuit...
Davi.p is offline   Reply With Quote
Old 02-01-2019, 10:41 PM   #35
samsonite
My Country: USA
Well, I finally got C102 off, got rid of my new capacitor too, and replaced it with a new SMD cap (KEMET 399-18658-1-ND). Powered up the TV and still not working. Red LED light keeps blinking forever. So, either the problem is somewhere else, or I toasted the board.
And I can't measure any voltages, because this is the backside of the board. After I screw the board in, and hook the cables up, you can't access it. Also, this board has 4 grounding screws, so I always make sure they make good contact with the board when I screw them in, so I see no issues with my re-assembly either.
Maybe I will replace these IC chips, IC101 and IC102, as a last resort.
Old 02-02-2019, 12:11 AM   #36
sean0118
City & State: Sydney NSW
My Country: Australia
Line Voltage: 230VAC
Yes, lead-free solder has a high melting point, but if you add leaded solder it will melt easier.
Then use two soldering irons, one either side to lift it off. Once it's removed use solder wick to remove all the existing solder. Then solder the new capacitor on, one pad at a time.
edit: Post a pic of the main board as it is now, with the new capacitor.
Might also be worth trying your original power supply board? In case the Shopjimmy one from your first post is faulty.
sean0118 is offline   Reply With Quote
Old 02-02-2019, 04:50 AM   #37
tvtimmy
tvtimmy's Avatar
My Country: usa
There is one more cap on the top side of the board you could try and replace. I can't remember where it's located, but I know it's in a tight spot.
Old 02-02-2019, 04:33 PM   #38
samsonite
My Country: USA
Well, it's not too pretty. The board still has flux on it, and I put too much solder on the pads, and had some trouble getting it off, so I left it for now. And I accidently got some solder on R107, and had some trouble getting that off too, which is why R107 looks charred. And you can't tell from the photo, but the SMD does have a small stripe on one side indicating positive polarity, but not visible here.
BTW, is there anyway to reset the power cycle on a TV, so it no longer blinks when plugged in? It seems to be stuck in an endless loop. Unplugging and waiting doesn't work for me.
Old 02-02-2019, 09:07 PM   #39
nomoresonys
My Country: U.S.
Mainboard there for 20 bucks BUT untested. https://www.ebay.com/itm/Samsung-LN4...frcectupt=true
Old 02-03-2019, 01:20 AM   #40
samsonite
My Country: USA
It's tempting to buy another board, but I've already invested some money into this project.
But, if I were to buy one, it would have to be a 100% working board. Not a repaired or salvaged board. It would have to be a board with new parts that have been replaced. Some people advertise repaired or salvaged boards as "refurbished", without replacing a single part. I already have an old board with old parts, I don't need another one.
BTW, the Ebay pic of the backside of the board, it looks like c102 has been replaced with a banana colored capacitor. But, since they say "not working", maybe it was a failed attempt.
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Badcaps.net Technical Forums 2003 - 2019
Powered by vBulletin ®
Copyright ©2000 - 2019, Jelsoft Enterprises Ltd.
