Badcaps.net Forum
Go Back   Badcaps Forums > Troubleshooting Hardware & Devices and Electronics Theory > Troubleshooting Computer Displays
Thread Tools Display Modes
Old 03-17-2018, 08:55 AM   #1
Lanikor
City & State: Pirot
My Country: Serbia
I'm a: Knowledge Seeker
Default Samsung SyncMaster T220 weird flickering
Hello everybody, you've probably seen threads with this title more than several times but this looks a little bit specific and i couldn't find a thread with the same exact issue as mine since my display isn't turning off so i'm going to ask as a preventive measure before i waste the money on changing the capacitators (which i should do anyways but i just want to be sure that this is the only problem this display has).
So the symptoms look like this:
Couple of days ago it started to develop this weird flickering that looks like the backlight is flickering extremely fast in the upper part of the display and it is so fast that it's barely visible but it began to spread more and more during last couple of days and now it drives me crazy as it acts like a small strobe light.
The only way i can show you this behavior is by uploading a video because it cannot be captured by a single snapshot or two, even in the video it's not that apparent because the camera can't record it properly.
So here it is, it's not that visible in the video until you pay atention to the flashing of the light, that's actually what is going on and it's more evident when you're looking directly at it (ignore the irritating sound, it comes from the washing machine):
https://www.youtube.com/watch?v=45AEO8xS4oI
Lanikor is offline   Reply With Quote
Old 03-22-2018, 01:29 PM   #2
CapLeaker
Leaking Member
CapLeaker's Avatar
City & State: Atlantic Canada
My Country: Canada
Line Voltage: Ground, 0Hz
I'm a: Hobbyist Tech
Default Re: Samsung SyncMaster T220 weird flickering
what happens if you turn the back lights down? Does this go away once the monitor ran for a while?
CapLeaker is offline   Reply With Quote
Old 03-22-2018, 06:39 PM   #3
Lanikor
City & State: Pirot
My Country: Serbia
I can't control the brightness through the display buttons since i use HDMI>DVI adapter to connect it to my laptop which has HDMI and Mini Display Port ports, this monitor transfers the controls to the dedicated software when i use DVI port on it.
I can change settings only through Intel Control Panel (so through software only). Connection isn't loose, HDMI cable is 100% flawless. I use APC Surge Arrest extension cord so power supply isn't an issue as well.
It was really annoying for last couple of days, now it calmed down but it's still noticeable and that is bugging me out. I figure that you're connecting the dots with the "when it heats up, problems go away" theory but it was completely random for the past couple of days regardless of the amount of time the display was turned on and it can stop for like 10 minutes and starts flickering when the dominant color on the display changes.
Old 03-22-2018, 08:43 PM   #4
CapLeaker
Leaking Member
CapLeaker's Avatar
My Country: Canada
I am guessing that if you squeeze the frame of that monitor around the area where it flickers, nothing changes? All you can do is to set the back lights lower and see if that does get you somewhere. Other than that, you would have to open her up and check for bad caps, clean and reseat all the ribbon cables, etc. I am not really convinced it is a back light problem that you have, could be also a tab bond... that's why I want you to squeeze that frame hard. You say that this flicker problem is only at the top left, correct?
Old 03-23-2018, 06:34 AM   #5
rddube
Aspiring Expert
City & State: Montreal, Quebec
My Country: Canada
Line Voltage: 120VAC
Check the refresh rate of your software and make sure it corresponds to the monitors optimal refresh rate. Happened to me once, they were out of sync and I had flickering similar to yours.
rddube is offline   Reply With Quote
Old 03-23-2018, 04:28 PM   #6
Lanikor
City & State: Pirot
My Country: Serbia
I tried to squeeze it and watch out the behavior for some time, so far it looks like nothing changed, the flickering isstill there, it's barely noticeable, but it was like that for this entire day and also yesterday.
Predominantly the issue persists in the top left corner.
Refresh rate is set @ 60Hz on both displays. No other options are available, i could maybe override it manually but i have never tried that before.
Old 03-27-2018, 12:55 PM   #7
Lanikor
City & State: Pirot
My Country: Serbia
Now it rarely flickers once it gets turned on, i don't have a clue what's going on, i'll pass it to a technician to change the capacitors nevertheless, it's ~10 years old, refreshing is due.
Old 03-27-2018, 02:57 PM   #8
Th3_uN1Qu3
Believe in
City & State: Bucharest
My Country: Romania
Line Voltage: 230VAC 50Hz
I'm a: Professional Tech
It does sound like bad capacitors, they sometimes regain part of their capabilities once warmed up. This will not last long until they fail for good.
__________________
Quote:
Originally Posted by PeteS in CA View Post
A working TV? How boring!
Th3_uN1Qu3 is offline   Reply With Quote
Old 03-28-2018, 05:08 PM   #9
neisg1
City & State: Naicam, Saskatchewan
My Country: Canada
I had a similar flickering issue on a Lenovo monitor. turned out to be a heat sensitive cap on the video control board. Once warm it settled down but a shot of cooling spray on the caps revealed the problem.
neisg1 is offline   Reply With Quote
Old 04-10-2018, 06:46 AM   #10
Lanikor
City & State: Pirot
My Country: Serbia
Guys just to report with the update, flickering stopped on its own without me doing anything to the display, but since the weather is now getting hotter here, it's probably the issue that the last poster described.
Old 01-14-2019, 05:52 AM   #11
vitortec
VITORTEC
City & State: apucarana
My Country: brasil
i need firmware bios samsung t220 bn41-01029b tw22hqcs503291f
vitortec is offline   Reply With Quote
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Badcaps.net Technical Forums 2003 - 2019
Powered by vBulletin ®
Copyright ©2000 - 2019, Jelsoft Enterprises Ltd.
