Badcaps.net Forum
Go Back   Badcaps Forums > Troubleshooting Hardware & Devices and Electronics Theory > Troubleshooting & Designing Networks
Thread Tools Display Modes
Old 10-12-2018, 08:15 PM   #1
japlytic
japlytic's Avatar
City & State: Rockhampton, Queensland, Australia
My Country: Australia
Line Voltage: 240VAC 50Hz
I'm a: Hobbyist
Default No shares within a workgroup appearing
On a new Windows 10 install, I cannot see other computers on the network even though I am on the correct workgroup name despite seeing other network devices which do not use a workgroup and that network discovery is enabled and set for a private network.
I then discovered something in "Turn Windows features on or off" which was "SMB 1.0/CIFS File Sharing Support" which enabling it fixed this problem.
__________________
japlytic is offline   Reply With Quote
Old 10-13-2018, 09:22 PM   #2
Topcat
The Boss Stooge
Topcat's Avatar
City & State: Salem, MO
My Country: United States
Line Voltage: 120VAC 60Hz
I'm a: Professional Tech
Default Re: No shares within a workgroup appearing
This is disabled if you select 'public network' as network type.
__________________
<--- Badcaps.net Founder & Owner
Badcaps.net Services:
Premade Capacitor Kits
Badcaps.net Capacitor Master List
Motherboard Repair Services
If you've come here in search of replacement capacitors or repair services, please use the links above.
http://folding.stanford.edu/
Team : 49813
Join in!!
Team Stats
Topcat is offline   Reply With Quote
Old 10-14-2018, 08:50 AM   #3
seanc
City & State: Cambridge, UK
SMB 1 is disabled by default with build 1803.
Access to C$ or admin$ is also disabled unless you modify localaccounttokenfilterpolicy.
https://support.microsoft.com/en-gb/...y-registry-se/
seanc is offline   Reply With Quote
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Badcaps.net Technical Forums 2003 - 2019
Powered by vBulletin ®
Copyright ©2000 - 2019, Jelsoft Enterprises Ltd.
