Badcaps.net Forum
Go Back   Badcaps Forums > Troubleshooting Hardware & Devices and Electronics Theory > Troubleshooting & Designing Networks
Thread Tools Display Modes
Old 09-23-2018, 05:03 AM   #1
PopcornMobo
PopcornMobo's Avatar
City & State: Lithuania
My Country: Lithuania
Line Voltage: 220-240 VAC @ 50 Hz
I'm a: Knowledge Seeker
Default Is my DWA-525 Pcie network card crapping out?
I had this DWA-525 running in my WinME system that i used for remapping SAAB ECUs and it's been working well.
Lately my little brother asked me to build him a PC for minecraft and whatnot.
Routing network cables across my house is a pain in the ass so i thought i'd throw my DWA-525 in the PC and i'd be set.
One problem is that after installing drivers the card works fine and dandy but only for a very finite amount of time.
I can connect to WiFi and signal strength is good but after a few seconds the card craps out and no longer sees any networks or anything at all.
Disabling and then enabling the card in device manager gets it working for a short while.
The PC is an old DELL oem one running Win7, maybe the it's rejecting the card?
Ps: i know this is kind of a troubleshooting thread but i couldn't find anywhere else to put it, so i put it here in general discussion.
PopcornMobo is offline   Reply With Quote
Old 09-23-2018, 08:48 AM   #2
RJARRRPCGP
City & State: North Springfield, Vermont
My Country: USA
Line Voltage: 123-127V 61.5-63.5 Hz
Default Re: Is my DWA-525 Pcie network card crapping out?
Reseat the card...
__________________
Asus P6T Deluxe
Core i7 Extreme "Bloomfield" 965
PNY GeForce GTX 960
Windows 7 SP1
SoundBlaster ZXR
Corsair TX850M PSU
"Don't eat yellow snow!" -Salem
RJARRRPCGP is offline   Reply With Quote
Old 09-23-2018, 09:33 AM   #3
PopcornMobo
Quote:
Originally Posted by RJARRRPCGP View Post
Reseat the card...
Already did that a few times, switched from one slot to another, no bueno.
Old 09-23-2018, 10:00 AM   #4
stj
stj's Avatar
City & State: Europe
My Country: some shithole run by Israeli agents
I'm a: Professional Tech
is the psu good?
btw, how old is the card? i have burned loads of wifi sticks/cards when i used to crack networks - they often get far too hot when you run them continuous.
stj is offline   Reply With Quote
Old 09-23-2018, 10:41 AM   #5
PopcornMobo
Quote:
Originally Posted by stj View Post
is the psu good?
I can't see the date written anywhere, here's some info off the card.
P/N: RWA525A....A1G
H/W ver.: A1
F/W ver.: 1.10
S/N: PVOV1B5006504
Nothing else seems to be failing but i'll check the PSU.
If these overheat then maybe i could pull off a cheeky reball? Rehot WiFi card, bro.
Old 09-23-2018, 02:09 PM   #6
stj
stj's Avatar
i used to fit heatsinks to them.
back when i was seeding torrents over wifi 24/7!!!
Old 09-23-2018, 03:13 PM   #7
PopcornMobo
I took the PSU apart and found two bulged caps so i thought bingo.
Replaced them with some nichicons and the card still does what it did.
Although touching behind the card feels quite warm, might that the little BGA is overheating.
I'll try taking the shield off and sticking on a heatsink.
Old 09-23-2018, 03:19 PM   #8
PopcornMobo
Looks like i went off to modding the card before i posted the reply above.
Well i stuck on a rather large heatsink from an AGP GPU with the help of a thermal pad, double sided tape and a piece of steel bent to a C shape to press the heatsink against the BGA.
And *drumroll* the card works now!
Not sure whether it's the heatsink or the pressure against the BGA but the card works without crapping out now, which is what matters.
Now my little bro can play minecraft on his new pentium 4 520 beast gaming PC with a blazing fast 6600GT GPU and a whopping 2 whole gigabytes of RAM (it's what i had laying around ).
Old 09-24-2018, 01:42 AM   #9
ChaosLegionnaire
HC Overclocker
City & State: Singapore
My Country: Singapore
Line Voltage: 240VAC 50Hz
I'm a: Hobbyist Tech
might wanna ensure the case has enuff case fans to keep it well cooled. the 6600gt can run quite hot esp if it has the stock heatsink. the 6600gt typically runs at 80C or more with the stock heatsink! that and the presshot p4 cpu is probably whats making the internal case temperature so hot that the wifi card craps out due to the heat!
ChaosLegionnaire is offline   Reply With Quote
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Badcaps.net Technical Forums 2003 - 2019
Powered by vBulletin ®
Copyright ©2000 - 2019, Jelsoft Enterprises Ltd.
