Hello, on mainboard f5sl I have some problem: I measured the resistance value of these components, and they have a resistance of 78k, but look like capacitors. What are the components?
Asus F5SL bad caps
Re: Asus F5SL bad caps
They are multi-layer ceramic capacitors (MLCC), or often just called ceramic capacitors.
The reason you could see that 78 kOhm resistance across them is because they are probably connected in parallel with other components on the motherboard. So you are actually reading the resistance of some other component on the motherboard.
