LA-D711P bios image repair
    I need bios dump hp 255 g5
    motherboard bdl51 la-d711p rev 1.0
    my oryginal bios here
    Re: hp 255 g5 bdl51 la-d711p rev 1.0
    try
    https://www.badcaps.net/forum/showthread.php?t=66687
      works
        HP 15-ba025nl bios dump
        Hi, I need bios dump fot Compal BDL51 LA-D711P REV. 1.0 BID 081F5 AMD A8 GPU AMD Radeon™ R5 M430 216-0867071 25Q64FVSIQ 8MB.
        thank you
          Re: HP 15-ba025nl bios dump
          i found and work for me
            HP15 LA-D711P please bios image repair
            can anyone please check my bios image what is wrong?
            HP15 LA-D711P
            Problem - blank display only backlight.
            I have tested another bios image - all was fine but bios image was for mobo version with amd gpu.
              Re: LA-D711P bios image repair
              With any HP bios you should check your bios backup BID number ,or bios part number using a hex editors search function. Yours is BID081F5
              Then,search the forum to see if any bios have already been posted. https://www.badcaps.net/forum/showthread.php?t=66687 Post #3 has the virgin bios extracted from the update.
              With this bios the DMI info is in one big block and quite easy to copy,again using a hex editor.To search for the DMI i use a tool called FileAlyzer and searchthrough the hex for strings, but you can use insyde bios tools,UEFITool, a hex editors File-Compare function ,or the keyword HEBTEST or other methods.
              When you find the DMI area just copy it from your backup to the virgin bios,that will preserve the serial,Feature-byte and win key etc .
              Attached is the bios with your DMI
                ooh thank you.
                i will check it tomorrow and then let you know
                  Soo it is working
                  only programming mode message for 1 second but it is not problem ...i will leave it as is
                  Again Thank you
                    100% working old dump
                      Tested! Working Thank You. Teşekkürler dostum selamlar.
